1/16 Breda panzer I finished
So here’s my attempt at takom and ammo migs 1/16 Breda Panzer I. I haven’t really attempted weathering before and feel like it may have been a bit over done but then again warfare isn’t clean.
How was the kit for building?
@Dan the kit wasn’t bad, the rear deck was a hard fit and i used putty to fill some seams. The track was tedious work but it actually rolls when you put it on. The bicycle wheel suspension was pretty straight forward, the only down side is that you can’t put them on as the last item because they are secured on the inside of the hull in step 3 and the superstructure is a bit hard to get a hand in once secured to the hull. If i build another one of these id probably paint the lower hull and then work on the top.
