I managed to pick up Resicast’s Sherman BARV conversion for Tasca’s sherman III. While i have the base kit needed in the stash, I dont want to sacrifice a great kit for this build if necessary due to minimal use of parts.
A quesion for the shermanholics out there, can I use Tamiya’s M4 Sherman Early Production kit 35190 as a base donor kit? No engine hatches or the rear deck/hull will be exposed as seen in the images below.
Nick, The Tamiya M4 kit is what the British called a Sherman I, not a Sherman III.
The Tamiya M4 kit has a 3 part bolted transmission, whereas the Resicast BARV seems to be based on the Cast cover type, not bolted. I presume the intent is for this conversion to be based on this kit:
Not this one:
The top image of the Tasca kit is the one I have. I may just have to suck it up and use that one. Its such a nice kit to sacrifice though. More sherman parts for the spares box I guess haha.
