Tetrapod (concrete breakwater or wavebreaker) in 1/35 scale made. 7.8 metric ton version.
Added seam lines and a lift ring on the top.
Played with putting random holes on the surface but it became too tedious, so I left the rest for DIY.
So out of curiosity, I had asked an AI-generator website to create a 3D figure of Lieutenant Colonel Kilgore from Apocalypse Now using the photos below:
Would any of you buy this STL for 5 USD if I were to buy this design and upload it to my Cults3D page (in 1/35 and 1/16 scale)? Of course, it would need some revising to make it more accurate.
It is going to cost me 12 USD initially to download it. That means I need to sell at least 3 times to break even. Not sure if it would be worth it or not.
OG M1 Abrams sprocket made - it appears none of the existing kit parts look accurate. At the same time, the wheel hub is mostly hidden from a full view due to the side skirt armor covering the sprocket. Like this:
I don’t think the embossing on the wheel hub will be shown in 1/35..
A separate STL file for the wheel hub only is included if the user wants to do some “plastic surgery” to the Tamiya kit part A8 (devoid of any hub details) or Panda kit part C24 (which is a bit overscaled in my view) or simply attach to RFM kit part A10:
You know what is totally missing from any 3D designer as far as I can find, is a simple duffle bag. There are no WWII/Cold War single handle, nor modern double handle duffle bags that I can find. They would be pretty easy to make and are much needed, I think anyways. I know I would buy the files.
And that’s exactly why I mentioned them.
By the way, I can tell you from experience, since you’ve made molds, it’s way easier to crank them out that way than 3D printing - far quicker, ;less expensive, less waste. What are you using? I crank out most items at a rate of three minutes per.
No issue casting/molding them. I just prefer 3D printing at this point. I can set up 25 (or however many I can fit on the printer), walk away for an hour and do something else, come back and they look great.
