All of this talk about MRAPs reminded me that I really enjoyed building kits of them.
When Panda produced the only MATV kit, I bought and made several of them, each representing a variant. While these kits are not an easy build at all, the results can be pretty nice. I looked in the stash and still have a few of the Panda kits, and one from RFM. I’ve read that the RFM kits go together really well, so am looking forward to eventually building it.
The RG series of trucks by Kinetic build up pretty well, and as I noted before, the details are a bit soft.
I decided it would be a good idea to make an RG-33 AUV SOCOM, twice. These were essentially scratch builds, something that I really wanted to do, and building both was really challenging for different reasons. The first try was fine, but not great, but it was also done about 10 years ago, while the other more recently. The latter turned out a lot better, but it should have, as I have more experience.
As no kit for the RG 33 AUV exists, I used parts from two Kinetic RG-31 Mk5s, parts from an M1083 kit, and a lot of scratch work. The RG-33 is 6x6 and the RG 31 4x4. At first glance the RG 33 AUV can be mistaken for being similar to a Cougar, but once you get into looking at it carefully (which a guy can do thanks to walk around images from @18bravo, thanks Rob!) you’ll find it’s not actually that similar, hence using the RG 31s. Robs pics are really helpful if you are trying to go beyond what the box-art has to offer - on almost each step of a build.
I built two MRAPs, one the Legend resin kit, which came with solid axles. This is a nice kit, but I wanted to show a version with the TAK4 suspension, so scratch built that. I also made the MRV version, which has the TAK4 suspension in front and solid axles in the back (walking beam), which makes sense, as it’s a wrecker. For this I used the front half of a Panda MAXXPRO Dash DMX - as it has the TAK4, and don’t recall what the donor was for the back - but, with some time it worked out pretty well.
I still have a Legend MAXXPRO MRAP kit, and a Panda DashDMX (W/TAK4) in the stash, so might get after them next.
My initial interest in MRAP vehicles was because I could understand their purpose, how their suspension works, and thought they were interesting. I like off-road vehicles and suspensions in general, so these fit the requirement. As I recall, the evolution of these vehicles was just that - at the outset, there was an immediate need for heavy duty vehicles that could accommodate a chassis that would allow/could be adapted to fit a V-shaped hull that was IED/mine resistant. Then came the TAK4 suspension and other versions that were more nimble (“nimble” meaning independent suspension that could more easily maneuver in rough terrain), like the MATV. The solid axle version was similar to a civilian, heavy duty off-highway vehicle, which meant that it worked, but not as well as desired or needed.
Anyway, I’ll likely keep building kits of various MRAPs.
Nick
