Way more to come later. I appreciate any and all feedback. Thanks
Nice start on a nice topic.
J
I’m following your progress, great beginnings!
Dave ![]()
Following your progress.
I look forward to following your progress. Nice start.
I cut the road and bar ditches and added rubble to the inside of the chapel. Wire tree in winter was also added.
Hi @KGvonJaxx
for the Ardennes in winter ’44, most pines are in the 15–20 m range, which in 1/35 works out to roughly 43–57 cm, but going strictly to scale usually ends up looking oversized in a diorama.
What tends to work better is to vary things for depth, something like 35–50 cm in the back, 25–40 cm in the mid-ground, and 15–25 cm up front, mixing heights and keeping some of the lower trunks cleaner to get that dense forest feel.
Since it’s Bulge, it also helps to push a winter look a bit — slightly heavier tops, less overall foliage, and a few more irregular or “tired” looking trees.
Ricardo, that’s the sort of support and advice that really helps bring out the best results!
Thanks Ricardo, great information. I don’t really have the room so I think I will put another deciduous (without leaves) and call it good. I see a lot of them on photos of the area.
I think the scale looks good. but you need a lot of snow on the branches…
Snow comes later
I’m almost finished with the base, muddy road is complete. Added the 251/9 and some figures. More figures to come. I’m not the best with figures but I’m getting better. Ak interactive terrain and snow effects were used.
Jaxx
Good to see everything is coming along great, even your figures! ![]()
Are you planning on adding any other vehicles, or just more figures?
Thanks for sharing this, looking forward to the next installment.
Dave ![]()
I plan on adding more figures and a Jadgpanzer IV L/70 and one more wire tree in the open corner. Thanks
Great mud. Reminds me of one of the german news reels I have seen of the area in question during the battle.
J
Thanks, that was my goal. AK Interactive Muddy Ground is easy to apply straight out of the jar. Ruts are easy to create with a small brush or some old wheels. I tried to make tank tracks but it’s hard to see. The color I did not like so I used some Ammo mud wash and it turned out great.
