Thanks to all for the appreciation, ok let’s start from the beginning, the vehicle as it was for the M1 Abrams (that I still have to finish but I will do it soon), it was an old kit assembled when I was young, so I recovered it, disassembled it (the glue was so crystallized that the pieces remained together by gravity
) cleaned and then reassembled as if it were almost a new kit. Regarding the colors, when I did it I didn’t have the specific set and so I created them with what I had at home, a mix of light gray and light blue for the base, white gray from a Vallejo german set color and mix of brown tone, once dryed I did a drybrush with oils on the base color with Mig 502 german gray highligt, and on white with Mig Faded U.N. white, while on the brown I used an acrylic brown from Agama, after which I proceeded with a selective washing with oils and True-Earth products, while for the mud and dirt in general I used the liquid pigments of the lifecolor and for the various streaking I used oils with light passages, on the engine compartment I made abundant passages of liquid pigment for the dust / mud (it is known that the snow is very dirty), and Grease and oil of true-earth for the oil patches, all to simulate engine failures, very frequent with Leyland engine in that period. The few decals present were costumized by downloading the logos I needed from the web. The Marksmann radio box, on the other hand, was added later, no I had noticed its presence, I built it with plasticard and to insert it without damaging the color made I used epoxy dyed with pigments to recreate right color on the weld that also acting as a glue to fix it to the turret, even the gun has undergone a slight improvement, in the lower part I added the heat protection with a foil of epoxy, effective when the gun is fixed at 6 o’clock, and recreated the cloth that covers the slot at the junction of the fee with the turret, absent in the kit.
my refences pics for the tank
and the cause for the dirty engine deck
The figures, all from commercial sets and slightly modified, apart from the student to whom I recreated all clothing and hair with epoxy, the tank crews are two panzergrenadiers from the Tristar 004 set, to whom I recreated the cap and filled the belt, replacing the arms to get a posture more suited to my needs, painted in acrylic and finished with oil, I redid the communications switcher in plasticard with the addition of the strap to hang around the neck, what else is missing? if you have any other questions, feel free to ask
my references for the crew wear
the tank crew
I haven’t pics of the unpainted crew, sorry
Eskimo, I also wore it at that time, and it didn’t keep warm at all but it was a symbol here in Europe at that time
uh, forgot the cigarettes, I had done a research on the web to understand which were the most smoked cigarettes by the British at the time, nothing really in-depth but the result was this, true or false it was, so I printed the decals and added to the package on the side to the TC
