I have decided to end the year with this kit. I had started it at the same time as the B-10, but the bomber took so much work that I set the fighter aside. I have begun to modify a Pavla interior kit to fit this model. I have got some detail parts to go with it, wheels, the correct tail cone and a Quick Boost engine. It will be done in the same Dutch camo as the B-10. The Glen Martin will have a little friend!
Looking forward to Glen’s lil buddy Brewster. The ML-KNIL is a favorite of mine.
I have a Pavla interior for a Hasegawa Buffalo. I am modifying it to fit the Airfix Kit. I will add a oil wash ,before I glue everything together.
I got the fuselage together. It required some filling and sanding, but not too bad for a kit of this era. I had to fill in the AIrfix logo on the inside of the wing as this would have shown through the wheel well.
Good looking cockpit interior from Pavla Bill
I cut the original navel tail cone off and fitted a model 339 tail cone. This was intended for a Hasegawa kit, but with enough cutting, filing, putty and sanding I got it to fit. I also glued the upper and lower wings together and puttied the seams.
The first kit I got of the F2F was by Revell. After reading this article; Airfix 1/72 F2A-1 Buffalo, by Brian Baker , I decided to get the Airfix kit and use some of the Revell parts. The Airfix cowling is too short. The Revell is closer to scale. The Revell cowling is a good fit up and down, but is noticeably wider. It would only be attached at the top and bottom. I cut the Airfix cowling down and made it into an adaptor ring. The scale drawings show that the cowling is bulged and tapers back toward the fuselage. So, I trimmed and sanded the Revell cowl so that it would fit the fuselage better. I got the wings and tail glued on. It’s beginning to look like an airplane now.
Excellent choice! I just glosscoted my Tamiya F2A-2 Buffalo today. That’s nice work for an old kit in 72nd scale! John
A diamond in the rough - my money is on you to polish it into a gem.
Superb work with the cowl.
Thank you.
This model has been delayed two months, first by a cold, then the holidays, Covid and a hospital stay. But I have started work on it. I have painted the underside aluminum and masked off the bottom. I have got the first coat of green on. Next will be to mask that off and apply olive drab.
I just about got this plane painted. I just need to spray the landing gear. I made the roll bar out of wire. Next, is gloss coat and decals.
Great progress Bill. Interesting camouflage pattern…
Holy mackerel, how many hours did you invest in that paint and detail work? Excellent front canopy where the pilot gets in.
Looks fantastic Bill, great combo
