Building a 1/35th. Korean K2 Black Panther (2020 Build)
Another re-do 67 Pics. coming here.
The Wheels and track will be next.
Regards
Donald
The Wheels and Track.
More tomorrow
Regards
Donald
Nice work. I can see thew Koreans made the road wheel arms really beefy. As for the mud scraper on the drive sprockets, That’s a close fit.
Looks like an Abrams little brother.
And that’s a hard pass for me on those tracks!
Nodding here.
You are making a good work and a clear explanation.
I am very close to complete my model, and I had forgotten some small things that I’ve corrected later, for what was possible.
For example, the inner face of the mudguards is visible from below, so one has to make the rubber flaps thinner and fill the extractor circles, and close some gaps inside.
Besides, there is a point, between the turret and the boxes mounted on its sides, where the hollow space behind the boxes remains visible and should be closed in some way.
The hollow space under the poligonal things on the turret front (radar?) should be closed from below; not all the space has to be closed, only the part under the widest part of the things.
The box in front of the gunner’s position covering the optics has the front plate with the windows that should be placed not in vertical, but slightly inclined downwards to reduce the sky reflection.
I’ve not understood well if the large hole on the lower front of the gun shield should be drilled or closed by a black glass; being not sure, I have simply painted it black.
17 more of the assembly Pics.
Tomorrow the finished Pics.
Regards
Donald
Kit part looks like a banana!
I thought I lost everything , Just recovered the computer.
Here are the finished Pics.
This one is finished
Regards
Donald
