Model is taking shape. Riich Models made an extremey pleasant kit.
Very very nice. Some beautiful details there!
I just finished this Tamiya T-55A, with Eduard set and a few 3D printed items, as a DDR version. Minimal weathering - just some “grime”.
Another build brought over from 2024.Takom T-54 B with metal barrel and Polish conversion parts from MR Modellbau.
An interesting build, looks very good. This tank, with the two L-tanks, was in the NVA. As far as I know, the driver also steered it differently. The operation of the steering levers was completely different. I’m excited to see how the build progresses. By the way, what happened to your BAW-485? Is it finished? Or is it in the model graveyard? I would be very interested in the model.
Unfortunatly, I have too many projects on bench. The problem with the BAW build is the rear suspension. I learned that I can´t simply use the kits springs, but have to widen the distance between the wheels. I has been fallen out of sight now. O darn laziness!
Thank you for your quick answer to my question. I also get the impression from your collection that you have too many construction projects. I deliberately chose the BAW to ask you about its completion. The BAW is a very complicated model that you can’t just build casually. The DUKW is a good starting model, but that’s where the problems start. That’s where an intensive conversion of the base tub begins, which is completely different. I’ll come back to the topic of the BAW later when I introduce it here. I wish you the best of luck with your further construction.
Hi Joachim,
you are right about the BAW. It is different from the DUKW. But I don´t have not enough references to build the hull from scratch and also a lack of motivation. I started rebuilding the rear suspension right now. To me it´s enough when it just looks like a BAW. I rather concentrate on modern US Army, my area of expertise.
Gruß
Hans-Hermann
P.S. Your build of GSSD vehicles are simply great!
Hallo Hans-Hermann
Ich schreibe heute mal in Deutsch, ich denke das du der deutschen Sprache mächtig bist und es geht hauptsächlich um deln Problem. Ja, ich kann dich sehrgut verstehen, das du an dem Modell keine Lust mehr hast, mir ging es genauso wie dir. Aber das ist der Reiz am Modellbau auch Probleme zu lösen. Darum stelle ich dir heute mal paar Bilder vom BAW von unten ein, damit du dir das mal ansehen kannst. Deinen anderen Plan, kannst du ja immer noch verwirklichen. Habe gerade mit meinem Modellbaufreund über dein Problem gesprochen, wir haben damals zusammen jeder einen BAW gebaut, er ist der gleichen Meinung. Er hat nur NVA Fahrzeuge gebaut, aber sehrgut. Wenn du Hilfe brauchst, lass es mich wissen. Mache mit den NVA Modellen weiter, ich bin auf die Fertigen sehr gespannt. Schicke dir hier noch ein Bild von deinem neuen Projekt T-54 mit, vielleicht hilft es dir. Ansonsten wünsche ich dir und den anderen Modellbauern noch ein gesundes erfolgreiches neues Jahr.
Beste Grüße Joachim
Hallo Joachim, erstmal danke für die Unterstützung. Wie schon erwähnt, habe ich zu viele Interessen, Bundeswehr, US Army, einige NATO Armeen etc. Normalerweise habe ich von meinen Objekten eigene Fotos, teilweise sehr viele. Der BAW ist für mich “super exotisch”. Vielleicht sollte ich nur Fotos von fertigen Modellen posten? Wie machst Du es das Du von den ganzen “Russenautos” so klasse Modelle bauen kannst. Nur mit Fotos aus dem Netz? Ich komme aus Nordbayern, habe also einen ganz schönen Weg in die Neuen Bundesländer. Ich finde es spannend, wie viele Fahrzeuge nach der Wende erhalten ggeblieben sind, ganz toll.
Beste Grüße
Hans-Hermann
