Campaign - Royal Tank Regiment - 1917 and Beyond
Front hull almost done.
All it need now is the PE Light Guards to be bent and glued, along with the headlight lenses.
Call my Chieftain done for now. Final coating was done again with a 70/30 mix of Revell Clear Gloss and Clear Matt. Surprisingly it came out less dull than I expected. Antennas added with 0,3 mm spring steel wire, 60 mm long. All it still needs is a bit of Sennelager dirt.
Kit Tamiya 1/35 from 1976 :innocent:
Paints from Revell and Vallejo
My decals came in the mail not too long ago.
Now I can proceed with my build.
The lower hull is complete, minus some PE details.
Already started work on the turret. Gotta work on the loader’s periscope, the kit gives you choice of either molded plastic or PE brush guards for the periscopes, but oddly enough, it doesn’t give you 5 molded plastic ones, so it forces you to use one of the PE guards Gonna have to dig up a spare from my spares box, unless it’s lost during my move.
I’ll find one, one way or another. I gotta have it somewhere.
Looks super Torsten. Really nice and clean work. Cam looks spot on and it has a nice finished look as well… Very well done :+1:
Thanks John! Glad to hear that you like my efforts. As I mentioned, the Chief will get some dirt around tracks and skirts and a Union Jack on the antenna before the next model show, which takes place for me next March. Will be on display with some of my Leos then … :slightly_smiling_face:
Hi all, I thought I’d share an ongoing build that is part of the RTR’s pre-history! Sadly it was started late last year (but has stalled these past six months!) so is not strictly eligible, so I’ll also tackle a Comet later…
This build is a Mk IV “winder” designed for the planned landings on the Belgian coast to roll-up the German right flank in 1917 codenamed Operation Silence (also known as Operation Hush), but the op was cancelled when the Third Battle of Ypres turned into the bloody stalemate of Passchendaele. The tank was meant to climb the sea wall and then use a cable winch to pull other vehicles up from the beach, hence being called a “winder”. I am using the old Emhar kit because it was there in the stash, with resin tracks that also lurked in the pile! That, and a bunch of TLC managed to get me to the point where paint can be thrown…
My plan is to mount it atop a section of the concrete sea wall, deploying the winch cable!
Well, that’s all very interesting Tom; well done you for unearthing such a unique subject. Nothing wrong with specialised armour, and I’m aware there was quite a bit about, even back then, though I’d never heard of this one.
Sort of “sea-wall Normandy 1917”.
I have tried several paint formulas for the “Neutral Brown Color” for the British WW1 tanks.
The one I was most happy with was 4 parts Tamiya Earth Brown and 1 part Tamiya Buff.
I find anything earthy works once I cover it in all that mud!
In most of the photos I have of the tank, they are not caked in mud. Most are more dusty
I had spoken too soon about the fit being good.
That was for the running gear. Barrel and above all dozerblade proved to be suboptimal, to say the least. For the barrel base plenty of putty was needed to get an aligned square shape and the dozer fits badly, aligns even worse and I ended up glueing everything in place, so that nothing could or would move anymore.
The tracks have a bit of an issue as well; 4 pegs, 8 holes…
So far:
Okay I have decided to do the Bronco A34 Comet. Not sure if I will do 1 RTR or one of the 3 RTR markings at this stage.
I bought the kit when it was first released in 2005, at a time when PE was all the rage… and I succumbed to the urge to detail… I have Voyager fenders and their detail set for this. I wonder how much I’ll actually use!
I also have the Lion Marc Design barrel and their mantlet cover, plus the Indy track set Bronco released at the same time.
The kit has some issues, one of which is the hub caps on roadwheels, but I have cast up Cromwell ones to fix that.
Well, back at it again. I clear coated, decaled and dull coated the Mark IV.
Weathering is next.
Sorry for the delayed response. As I mentioned in the Straight Out of Box thread. Been hella busy, but here it’s my progress on the Sherman Firefly.
Just need to start working on the tracks and some minor details around the tank.
But I really do love this kit and how nice it’s going together.
