Hi Guys,
Could a P-40M be cobbled together from Eduards K and N kits? Of so what parts would need to be cut and stuck to accomplish it?
Mike
Mike, I have Eduard’s 1/48 Kit 8086 P-40M and Kit 82241 P-40E. There are a few of the P-40M’s out there. Here is a brief difference between the variants. Not sure if it’s 100%. But it looks like the fuselage was stretched like the P-40L but it doesn’t state what portion.
P-40F and P-40L, which both featured Packard V-1650 Merlin engine in place of the normal Allison, and thus did not have the carburetor scoop on top of the nose. Performance for these models at higher altitudes was better than their Allison-engined cousins. The L in some cases also featured a fillet in front of the vertical stabilizer, or a stretched fuselage to compensate for the higher torque. The P-40L was sometimes nicknamed “Gypsy Rose Lee”, after a famous stripper of the era, due to its stripped-down condition. Supplied to the Commonwealth air forces under the designation Kittyhawk Mk II, a total of 330 Mk IIs were supplied to the RAF under Lend-Lease. The first 230 aircraft are sometimes known as the Kittyhawk Mk IIA. The P-40F/L was extensively used by US fighter groups operating in the Mediterranean Theater.
P-40G: 43 P-40 aircraft fitted with the wings of the Tomahawk Mk IIA. A total of 16 aircraft were supplied to the Soviet Union, and the rest to the US Army Air Forces. It was later redesignated RP-40G.
P-40K, an Allison-engined P-40L, with the nose-top scoop retained and the Allison-configured nose radiators scoop, cowl flaps and vertical-stabilizer-to-fuselage fillet. Supplied to the Commonwealth air forces as the Kittyhawk Mk III, it was widely used by US units in the CBI.
P-40M, version generally similar to the P-40K, with a stretched fuselage like the P-40L and powered by an Allison V-1710-81 engine giving better performance at altitude (compared to previous Allison versions). It had some detail improvements and it was characterized by two small air scoops just before the exhaust pipes. Most of them were supplied to Allied countries (mainly UK and USSR), while some others remained in the US for advanced training. It was also supplied to the Commonwealth air forces as the Kittyhawk Mk. III.
P-40N (manufactured 1943–44), the final production model. The P-40N featured a stretched rear fuselage to counter the torque of the more powerful, late-war Allison engine, and the rear deck of the cockpit behind the pilot was cut down at a moderate slant to improve rearward visibility. A great deal of work was also done to eliminate excess weight to improve the climb rate. Early N production blocks dropped a .50 in (12.7 mm) gun from each wing, bringing the total back to four; later production blocks reintroduced it after complaints from units in the field. Supplied to Commonwealth air forces as the Kittyhawk Mk IV.
