Thank you for being happy for my wife. That’s so nice to hear.
The foam is actually just there to stop the parts from sliding around in the box. The support bracket should actually be strong enough. I hope so anyway, because that is also my biggest concern, that the model will not survive the trip without any damage.
If it weren’t for my wife, I’d not be able to indulge my model habit. Any modeler with a supportive spouse or family is fortunate and a healthy partner is a treasure beyond measure.
We just had a class on model boxes creation and transportation on Sunday. Since foam is “cheap”, I would be tempted to add some bracing in two parts to just support any possible movement and take stress off the plastic.
Not a bad idea, Ryan.
What would worry me is that the support would have to touch the surfaces. And that could damage the paint or small details. I think the jolting in the car causes more problems than the stability. I just pressed the support bracket again and I really think it is stable enough to survive the 130 miles. But I’m glad to read that you are all worried about the integrity of my model. Great model building community.
Jörg, I asked almost the exact same question in the meeting. The key is PU (Polyurethane) foam is the material used. You can cut small holes/open areas for the smallest details. The material is soft enough to protect but not abrasive enough to rub the paint off.
Here is an example I found to build your own box but the material can be cut to size.
I will try to show some examples I have later and do a wear test.
I think I understand what you mean.
Because what you’re showing in terms of packaging is really great. However, the cars are only a fraction of the size of my diorama and they don’t have any protruding, hanging structures. I would then have to line the entire box with foam to create support. And it has the dimensions 24x15x13 inches.
I was thinking more like two posts at an angle to support the angled section with bumps etc on the road. Kinda like when the team was in the trash compactor about to be swished. Not a full foam box like the car example.
@madtatt Jorg it’s great to hear that your wife is doing well and is encouraging you to enter your amazing Millenium Falcon into competition, where surely it will win the accolades it deserves
Good morning everyone.
So, I’m getting everything ready for the trip to EME.
Since Ryan’s suggestions stuck in my mind, I looked through my pictures again for the original diorama. I wanted to check how many and where I had attached the screws for the overhang. It wasn’t just glued. I found these pictures.
I think the only other thing you can do is if possible is to have the back facing a side door. That way if you should do any hard braking the motion is along the long side and not the short side.
I’m back from the EME.
Your fingers crossed and good wishes seem to have worked.
The little bird brought home some precious metal.
