Aaaargh! Visited my local model shop today - luckily open on a Sunday - and procured 2 x jars of Tamiya JGSDF OD. Applied to model - different colour! Lighter than what I’d used yesterday. presumably because my original jar was a decade or so old, and somewhere along the line, Tamiya, conceivably changed it slightly. I say slightly, but enough to notice so my only recourse - not wishing to add, say, black to the mix (and get it wrong further) - was to respray the whole. It’s still a fairly decent shade of OD and I hope it comes out OK for the timescale (1959), but a tad frustrating.
Probably time for a refreshing and soothing G & T - well, it is Sunday afternoon.
I won’t post pics of the new colour as there’s not really much point; it will, I’m sure darken a little when I apply gloss varnish in a couple of day’s time, I’ll then tackle the details painting phase and probably post then.
Well, it’s a wet February afternoon (is there any other sort?), so, coupled with the slightly askew paint scheme as mentioned above, the promised gin and tonic:
Well, just because I can’t work on the model, there’s nothing to stop me tackling the base.
One of my usual A4 (European paper-size) 12mm MDF type, edges sanded and stained and varnished - not visible here as I’ve masked it all off.
The idea is a simple German road, so I’ve initially scattered model railway scenic stuff along the verges to represent the detritus that tends to gravitate there.
I was quite pleased with this though perhaps the texture isn’t really that discernible on the pic; the colour is quite good too, though I’ll probably end up painting it a shade or two darker.
I had that with Mr. Aqueous about a year and a half ago: sprayed a model but the bottle ran out about three-quarters of the way through. Opened a new one, and it was noticeably different. The only solution was to spray all of it again with the new colour, essentially wasting all of the old
It’s hugely frustrating - I’m not convinced I’ve got the right colour, even though I often proclaim that I’m not a fan of huge accuracy when it comes to colours, but I really thought I was half way there to the correct colour with the original application, which was looking quite close to what I wanted, viz:
Unfortunately I saw that coming when you said you were out. Tamiya has changed the formula for OD a few times, not sure about XF-74 but I am not surprised if that is the case.
Thanks Ryan; it irks me more than it should. I’m sure I’ll get a result but I know it will probably niggle away at me.
The solution of course is to mix another batch, make it a tad darker, and re-paint, but having done that once, there’s only so much one can do. I’m not inclined to strip it all down, so I’ll have to soldier on with what I’ve got.
Sure, I’ll get something half-decent from the beast, and I’ll just have to ignore the niggle.
The gloss varnish may work in my favour - we’ll see!
Might not be the most economical but when low best to get another bottle to start and finish a project. Left over bottles can be mix when there is enough so at least they stay consistent throughput that project.
Yeah you’re right Tim, save that Armies don’t often accept that - especially in peacetime. I think I’m probably fretting too much and it’ll be fine, somewhat akin to Adolf Hitler in his bunker perhaps.
It’ll be displayed as a singleton in any case (though I did consider an M38A1 Jeep!) and hopefully I can pull it off - ie sufficiently interesting.
Try an overspray with very thin Tamiya smoke. Very thin so you can slowly build up the color to the desired shade. Test first but I have used this method before with good success.
Thanks; I’ll take it a step at a time. First stop to see what the gloss varnish does. If it’s still not what I want then I think I’ll give that a go. Thanks again.
Just in passing interest, there is a US TV series called “Loki”, about which I know nothing at all, save, in a couple of shots from the series, there is a derelict TV-8 shown:
You know, I watched that, and just thought it was an artist rendition of a "SciFi " tank … never gave it a second thought. Interesting on how they chose the TV8 as a prop for the show.
