Hi Charles
According to the info here https://avspare.com/caterpillar/link/6y1130/ and here https://avspare.com/caterpillar/shoe/7t2294/
the track chain alone (shoes not included) weights around 1519 kg and each track shoe weights 36 kg. I let you do the math
tiking
18 November 2020 10:42
22
Ouch! Thanks buddy. I would need huge forklift for that. Ok, that forlift I was considering definitely won’t work. Ok. Thanks man.
tiking
10 December 2020 10:59
23
Have done some changes since the last update.
Re-arranges a couple of the figures
Added oil spills and oil absorbents(they are basically materials used to help soak up as much oil spills as possible.
Re-arranged the cab and pallets to make room for a forklift.
Added a couple of fire extinguishers. Will have to add a couple of signs too.
I managed to straighten out the kink in the overhead crane. Probably not 100% perfect but way better than in the last update.
Things left to do:
Add a figure in the forklift.
Some minute details.
A couple of signs.
Finishing off the forklift. Still need some detail weathering here and there. Then complete it with a coat of matt solution.
And whatever comes to mind that will fit the space. Hope you like what you see. Until the next update. Thanks for looking.
Awesome once more… I worked in a car garage for a while when I wore a younger mens’ clothes, and they used some sort of cat grit for oil spils… might be a nice addition…
Now this is one real piece of art, plain and simple! Stunning!
tiking
11 December 2020 09:51
27
Thank you. Yeah. Seen those before.
tiking
11 December 2020 09:52
29
Thank you so much. I appreciate it.
That’s as impressive as original. Whatever angle you’re looking at your dio from there are so many details to discover that it is incredible.
Olivier
