Does anyone know the story behind this photograph?
That is where I saw it as well. Always made me wonder. what was going on. I wondered if they did it as type type of camouflage or if they had “liberated” the car and it had been sitting up on blocks or something to explain the missing tires and that is why it was being carried the way it was.
Like they said in the old Tootsie Pop commercial back in the 1970s…
Now you see? You went and got in a second last word. One wasn’t enough. My bad, you may be ambidextrous so you still have one more hand to use tonight.
I don’t recall being condescending. In fact, I can recall driving almost two hours (a five hour trip) to get photos of an M106 Mortar carrier for an other member (one who loves to disagree with me as well) and I wasn’t condescending. I didn’t call him ignorant. (he’s not) I simply posted the photos for him. And guess what his response was? Thanks! Imagine that?
Speaking of two hour drives - how many M48s do you reckon are within a two hour drive of Zeeland? I’ll give you a hint - it’s more than one.
Maybe you’re just butt-hurt because I corrected you on M-L, just like I would anyone else. Was I rude?
I certainly don’t think so. So, maybe it’s time to grow a thicker skin, or start collecting stamps. :grinning_face_with_smiling_eyes:
Have your third “last word.” I’m done here. Don’t forget lube.
And yes Blackball, to move it along as you say, air cover was my first thought at the beginning of the thread. A car with no tires is kinda like a rifle with no firng pin.
I would like to compare the axle distance of the Balilla with the distance between the outsides
of the armour. I could imagine that adding the tires would require thicker planks to keep
the car stable.
The white paint on the fenders and the black out covering on the left hand headlight suggests miltary usage.
I think it is rather useless as camouflage.
There are simpler ways to create a totally unarmoured elevated observation post.
It weighs around 1500 pounds.
Somebody with sufficient influence wanted it moved from point A to point B.
Photo is dated 1943.
The invasion of Sicily was 9th of July 1943,
the Strait of Messina was crossed 3rd of September, Italy surrendered on the 8th
Naples was taken on the 27th and the fighting continued until Germany surrendered 1945.
Maybe someone could identify a probable location in Italy based on the building style,
I can not. It could be a unit doing a tactical withdraval and the commander orders that
his tireless command car shall be saved.
Maybe those darn Duke boys had something to do with it!! :laughing:
If you know…you know. :slight_smile:
Wow some of you guys GET IT TOGETHER and/or take your medications, and take it outside. Just get the eff out of this thread, use PMs if you want to continue a futile sh!t-fight. The rest of us really don’t care.
The question is about the photo, and the story behind it.
The fact the tyres are (deliberately?) missing makes me wonder if it was converted for rail? If so maybe that’s the reason it was worth salvaging.
The Balilla, IF the car is indeed a Balilla, has an overall width of 1480 or 1482 mm.
Standard gauge is 1435 mm which leaves 45 or 47 mm in total which would be
22.5 or 23.5 mm per side. The flange of a railroad wheel would need to be,
at most, 23.5 mm inside of the maximum width of the car.
The outside of the rim is already further inboard, the inside edge of the rim
is even further inboard.
Most narrow gauge railroads in Italy were built with 950 mm gauge (metre gauge but they measured between rail centres and not the inside edge, sigh …)
Doing the maths again: 530 mm in total or 265 (267) per side could work out.
Considering that the narrow gauge lines were mostly shorter local operations I think
it would be unlikely that they bothered with such a conversion.
Maybe the tyres were destroyed and they needed to move the car to some depot where they could get som tyres?
In my opinion, the tires were removed so that the bottom of the car would rest flush on top of the half track. If the tires were still in place, the car would not sit flush and be unstable.
My computer says the car probably has a provincial Italian license plate. I think someone in charge decided to pinch his favorite car when it was time to pull out. For some reason, it was easier to stick the car on the half track, maybe to save gas.
Agreed on reason to remove tyres…which now makes we wonder if they were chucked inside the half-track or the car.
How a group of photographs can fire our imaginations!
Interesting comments everyone!
My easy answer was a little more boring. Put the car on top of the halftrack… It would make for an interesting idea on camouflage. Thinking a fighter pilot would be fooled into thinking it was a civilian car driving down the road. (Probably wouldn’t work if it was cross country!)
Yep! I can imagine them laughing their asses off while joking about how viewers and historians in the future will struggle to figure out what the actual F is going on …
Except the guy up top who lost his seat to 4 tyres :joy:
Military forces in almost all countries have requisitioned civilian cars and trucks, from their own population or from occupied territories.
If a vehicle moves on the road in or near a warzone it is probably military, civilians had no gas/petrol and their movements on the road were restricted.
Aircraft do not always (close to never) have time to check out a moving vehicle before attacking.
When they get close enough to distinguish between a civilian Balilla and a commandeered Balilla they are already far past the point where they need to pull up to avoid ground contact.
Loitering at low speed near a potential military target is very often bad for the health (crazy
dudes shooting at the aircraft).
If the pilot against all odds was indeed capable of distinguishing between a Balilla and a kübelwagen he would be very able to see the halftrack as well.
I have to ask myself how you have ascertained that. And no, I myself did not work in a North American Aviation factory, or a dynamite factory. And this is also not to defend the “Aerial camouflage theory” either. it’s simply to put the record straight on what pilots actually can see.
I’m sure many of us remember this incident. There was a thread on it. Skip to 1:42 if you like:
Now let’s look at visibilty forward and down from say, a P-51, which was used heavily in the ground attack role in '43 - especially the Allison engined version.
For starters, it’s not as good as you might think.
Official wartime P-51 tactical trials documented that the forward view over the nose was restricted to a mere 3 degrees and 4 minutes below the sight line. In flat, level flight, any ground target closer than several thousand feet ahead disappeared completely beneath the engine cowling.
Now here is something I do have some experience with - the PC-9M in the CAS role. We were briefed by the Slovenian pilots who flew them during CAS training in Germany. Bear in mind it’s purpose built for its role. Pilots repeatedly told us that they can’t see as well we think they can. (for our own safety, as we were the ones calling them in)
A black car traveling away from the pilot, hundreds of feet up, resting on a camouflaged vehicle? And perhaps with a dust cloud behind it? It might very well pass. He can’t see well to his front. Trying to look down on either side there’s this big thing in the way - see video.
But I don’t like to rely on Youtube videos as my only “research.” (I only happen to remember that from the accident anyway)
What I have also done, other than sleep in a Holiday Inn Express, is conduct helicopter missions looking for ground targets in Afghanistan. I’ve posted the videos here recently. It is often very difficult to say with certainty what you’re seeing from only a few hundred feet, even in a slow moving helicopter, hence my telling the pilot to get down lower in the video.
This is American pilots we’re talking about here. No, that wasn’t how they were trained then, and is not how they are trained now. Yes, we’ve had those same CAS meetings with pilots of slow and fast movers in Afghanistan and Iraq. We, and they, call it target discrimination. If you cannot discern a target with absolute certainty, you do not engage. Period.
Yes, Google friends, you can find plenty of instances where mistakes were made. But let’s not make statements that are simply not true.
Would putting a smallish civilian looking car on top of a halftrack make an ounce of difference as far as the pilot is concerned?
If it gave him pause long enough to give them time to unass the vehicle - I know it would make a difference to me if I were in it.
Camouflage is often misunderstood by people. (again, we don’t know that’s what it was for, but for the sake of argmument) It is not always meant to totally and forever conceal something. But if it works just long enough to give you that tactical advantage.
Like tanglefoot barbed wire…same concept.
I would personally prefer to have one dude checking for aircraft when on the move.
Blocking upwards visibility by loading a car on top would not be to my liking.
Hear aircraft → check for aircraft. See aircraft → decision time: leave road/vehicle or not.
We were taught to leave the road as soon as we detect aircraft
OR
when we need to stop for some reason.
Most Swedish roads have forest beside them, roads over open fields would be scary
but spreading the vehicles to avoid a tidy line of targets is still an improvement.
Getting off the road in mountainous areas in Italy could be difficult …
You can also fool him by switching on the Fiat left turn signal and then turning right…
That won’t work. Fiats just work that way.
Honestly, I don’t think the “camouflage” theory holds up. Although the term “free fire zone” wasn’t actually used by Allied ground support pilots, the concept was certainly in widespread use. If it moved, it was “fair game,” especially for motor vehicles and trains.
So, trying to disguise your SdKfz 250 halftrack by covering it with a civilian car would have been a pointless exercise. Any motor vehicle observed in the open and moving in Axis controlled territory would have been taken under fire. Every Allied fighter pilot with the chance would have pounced on that target as soon as he saw it in the open. No doubt this arrangement is also top-heavy, likely overloads the 250 halftrack, and would have severally restricted any thought of driving off-road.
I think it’s actually more likely that the reason why the car is in such nice condition is that it was probably parked in the owner’s garage / barn because he couldn’t afford or obtain rationed gas to run it, was aware of the very likely danger of even driving it, and maybe even removed to tires to sell them on the black market. Leave the rims on the axels since that makes it possible to at least roll it about in the garage or barn to move it out of the way. Parking it to preserve for some more peaceful future was maybe the wished for best outcome.
So, my best guess is this is a nice car, in very good condition found hidden (by its owner to preserve it for later) away which has been looted / “confiscated” by the occupying Germans. It’s on its way with its new owner. The SdKfz 250 is just being used as a temporary means to move the car a fairly short distance to some maintenance location or railhead where it will be put into running condition to be used by the unit commander or to shipped back to the unit’s rear detachment in Germany.
Of course, the “new owner” might have legitimately purchased it, or it has been seized under some legal pretext of a proclamation by the military governor, etc. At any rate, some poor civilian has watched his prize car being driven off into the sunset, never to be seen again…
For fun I showed it my post from another recent thread. ChatGPT’s answer follows it:
Thoughts?" Google AI also states:
The image was taken in Italy around 1943 during the war.
[/quote]
That’s funny. I’ve taken a graduate level class on the use of AI and attended a few seminars on it. That doesn’t mean I know anything more than anyone else could learn in five seconds by simply asking Google, ChatGPT, Grok or others how they operate.
What we’re seeing is something similar to citation laundering. A speculative claim is discussed online, indexed by search engines, summarized by AI, and then repeated with a citation attached. The citation can make the claim appear more authoritative than the underlying evidence actually supports. If you ask it now, it will give likely answers and now includes the very speculative conversation we are having as its “source.” Which is exactly why I don’t use it for such things. Here’s part of it:
These “tools” are exceptional at helping me with my novel, going so far as to offer a psychological analysis of the characters, correct grammar, offer tweaks, and trying to predict what will happen next. Sometimes I will tell it just for fun to write the next scene based on what it’s seen so far, and it can generate some surprisingly good twists, but the writing is horrible - full of cliches and far too many adjectives. Think “ it was a dark and stormy night. Even though it appears to invent a story from scratch, it’s doing so by predicting what narrative elements, character actions, and writing styles are most likely to fit what came before.
In short, if it doesn’t know definitively what you’re showing it, it’ll give you its best guess. Someone who has looked it up reads it, posts it like it’s gospel, and eventually it almost becomes the truth. Exactly why I make a point of busting out certain people on this site when they post tripe - over the years, even before AI, people have begun to drink the Kool-Aid with out even knowing what flavor it is. Most recent example - very recent discussion on M-L in which some are still saying you need to add a shim to the Tamiya M48 turret. I have proven with my own research that is not true, and even posted the results on the archived Armorama. Because I have no desire to waste time in their discussion, I posted a link that sort of alluded to my post, and didn’t mention Tamiya specifically, and this must not be true because they couldn’t find it. AI can make you very lazy if you don’t do your own research, just like they tell you at the bottom of their answer.
[/quote]
For fun I asked it about my post in another thread. It couldn’t see the whole thread:
Thoughts? Google AI also states: The image was taken in Italy around 1943 during the war. That’s funny. I’ve taken a graduate level class on the use of AI and attended a few seminars on it. That doesn’t mean I know anything more than anyone else could learn in five seconds by simply asking Google, ChatGPT, Grok or others how they operate. What we’re seeing is something similar to citation laundering. A speculative claim is discussed online, indexed by search engines, summarized by AI, and then repeated with a citation attached. The citation can make the claim appear more authoritative than the underlying evidence actually supports. If you ask it now, it will give likely answers and now includes the very speculative conversation we are having as its “source.” Which is exactly why I don’t use it for such things. Here’s part of it: IMG1631 IMG1631 613×516 107 KB These “tools” are exceptional at helping me with my novel, going so far as to offer a psychological analysis of the characters, correct grammar, offer tweaks, and trying to predict what will happen next. Sometimes I will tell it just for fun to write the next scene based on what it’s seen so far, and it can generate some surprisingly good twists, but the writing is horrible - full of cliches and far too many adjectives. Think “ it was a dark and stormy night. Even though it appears to invent a story from scratch, it’s doing so by predicting what narrative elements, character actions, and writing styles are most likely to fit what came before. In short, if it doesn’t know definitively what you’re showing it, it’ll give you its best guess. Someone who has looked it up reads it, posts it like it’s gospel, and eventually it almost becomes the truth. Exactly why I make a point of busting out certain people on this site when they post tripe - over the years, even before AI, people have begun to drink the Kool-Aid with out even knowing what flavor it is. Most recent example - very recent discussion on M-L in which some are still saying you need to add a shim to the Tamiya M48 turret. I have proven with my own research that is not true, and even posted the results on the archived Armorama. Because I have no desire to waste time in their discussion, I posted a link that sort of alluded to my post, and didn’t mention Tamiya specifically, and this must not be true because they couldn’t find it. AI can make you very lazy if you don’t do your own research, just like they tell you at the bottom of their answer.
Answer:
I think that’s one of the more thoughtful critiques of AI I’ve seen in a hobby forum, largely because the poster understands both what AI is good at and what it isn’t.
The strongest part is this:
“A speculative claim is discussed online, indexed by search engines, summarized by AI, and then repeated with a citation attached.”
That’s a real phenomenon. I’d probably call it “evidence amplification” rather than citation laundering, but the basic concern is valid.
Here’s a simplified version of what can happen:
  1. Someone makes an educated guess in a forum.
  2. The guess gets repeated on three other forums.
  3. Search engines index all four discussions.
  4. An AI sees the same claim in multiple places.
  5. The AI concludes, “This is probably true.”
  6. The next person sees the AI answer and assumes the matter is settled.
The problem is that four repetitions of the same unsupported claim are still one unsupported claim.
Where I think the poster is particularly insightful is his comparison to long-standing modeling myths. The Tamiya M48 turret example is exactly the sort of thing that existed decades before AI. A respected modeler says something in 1998, another repeats it in 2003, somebody cites it in 2007, and by 2025 it has become “common knowledge.” AI didn’t create that process—it can accelerate it.
I also agree with his observations about creative writing.
When he says AI can:
  • analyze characters,
  • spot inconsistencies,
  • suggest plot twists,
  • fix grammar,
but produces prose that feels cliché-ridden and adjective-heavy, that’s a common experience among experienced writers. AI is often better at structure than style. It can identify that a scene needs more tension or that a character arc is incomplete. Actually writing memorable prose is much harder.
The one place I’d push back a little is here:
“If it doesn’t know definitively what you’re showing it, it’ll give you its best guess.”
That’s true of many AI systems, but it’s also true of many humans. The difference is that humans often signal uncertainty better—at least good researchers do.
A good historian says:
“Possibly Italy, 1943, based on uniform details, but I don’t have enough evidence to be certain.”
A weak AI answer might say:
“This photo was taken in Italy in 1943.”
Same underlying evidence. Different presentation.
For a thread about an unidentified photograph, that’s a huge distinction.
What’s interesting is that the poster’s actual workflow sounds a lot like how I’d recommend using AI:
  • Use it for brainstorming.
  • Use it for editing.
  • Use it for generating hypotheses.
  • Don’t use it as your final authority.
  • Verify anything important independently.
That’s especially true for historical modeling. Your Berlin exhibit is a perfect example. If you ask me what color a 1987 East Berlin storefront sign might have been, I can give you plausible answers and even point toward examples. But if you’re about to spend hundreds of hours building the thing, you’d still want period photographs. The photograph beats the AI every time.
So my overall reaction is that the post is neither anti-AI nor pro-AI. It’s really a defense of research discipline. The author’s central argument seems to be:
AI is useful, but it can make people lazy. The danger isn’t the tool—it’s treating a plausible answer as evidence.
For historical research, modeling, and museum-quality work, that’s a fair warning. In fact, it’s probably the most important warning.
