Dspiae Reciprocating Sander
Greetings y’all.
I’m considering picking up a Dspiae Pro reciprocating sander, but wanted to check in here for thoughts, experiences, and suggestions. Also a source for an original unit. eBay is full of knockoffs.
Thank you for your help
Only used mine a couple of times but it does what it says on the tin. As for a genuine supplier you don’t mention what part of the world you’re in.
Amazon page
Thanks guys. After reading the Amazon reviews I think I’ll just carry on with my sanding sticks.
Hi Ddek,
I have the red version for some time now (think 2 years) and i thoroughly enjoy using mine and can only say that it’s great. Never had that any of the ad-ons broke as in the Amazon comments maybe it only apply’s to the grey version. It will save you a lot of sanding time but to be honest i also use the old fashioned way of wooden coffee stir with glued on sanding paper.
Anyway my 10 (euro)cents
I’ve had very positive experience with the tool so far. Extremely useful for sanding little corners of my 3D prints. Highly recommended from me.
I second the remarks from both @Petition2God and @EHAM0624.
It is ideal for sanding in tight spots, because of the tiny surface and minimal movement of the head.
Ok, guys. Jan, James, Erwin. Thank you very much for your recommendations.
Now, despite the negative A’zon reviews,I’m leaning back towards pulling the trigger. It seems ideal for removing seam lines in harder to reach areas.
I have both the recipocating sander and the sanding pen. While the sander works OK, I find myself using the pen much, much more as it just seems to work better and is much more multi-functional.
https://dspiaestore.com/products/dspiae-es-p-portable-electric-sharpening-pen
Well, it is one of the most used things I have, I really like it, I bought an extra set of holders, for faster change. I use it for small corner sanding, or big areas
all sanding, including the removing work of about 1mm on the turret, was done with it…
I would buy it in China, via Aliexpress, if it is possible for you
Rabbits
Don’t know where in the world you are but Dspiae do have their own shop on Amazon or at least they do in the UK.
Purchased mine on Amazon US. I was a little skeptical at first and when it arrived, I found the speed button a little clunky to get used to. Also, had to learn how to position the tool so as not to knock off or bump adjacent parts… just a learning curve. Now I reach for the sander on a regular basis. HTH
—mike :hammer_and_wrench:
I have it, I don’t use it a lot, but it does work when I need it. The main issue I can think of is that the motor is not very strong, so if you push hard, it will stop, which makes it only good for finer sanding.
FWIW: I find it good practice to keep sandpapers and files clean, they’ll remain useful longer. I highly recommend these:
Rubber Cement Eraser, Glue and Residue Eraser
Note: I am not affiliated with any manufacturers or vendors.
Thank you all, gentlemen.
The consensus is in. I’ve just ordered the Pro off Amazon. Mike, I went ahead and grabbed a pack of erasers as well. Thanks for the tip.
Rabbit, Bulldog, (better not let you two in a room together), George, Jon, Paul, Ringo-I thank you all very much.
As mentioned already, it’s great to get into those hard-to-reach areas; as I’m endlessly modifying and converting figures (Cold |War modeller that I am) I find it invaluable for sanding away details that need to go before I apply whatever it is I’m trying to do; all those fiddly seam lines and the like that have to go? This tool will greatly help.
My Review Testing the DSPIAE USB Sander
