Has anyone used the FabScale Fa35027 1/35 U.S. M113 APC Tracks for Academy/Dragon Kits ?
I just bought a set and wanted to hear review comments on these …
Hi Brian,
I for one will be interested how you get on with them. I need a couple of sets and not 100 percent which way to go!
I have used all of these and they are all very good in their own right.
quickwheel look great, go together easily and fast, did two runs in under an hour.
R Model and Friulmodel both lend weight to the kit and sit nicely. R Model easier to put together as the pins come with the track, Friulmodel, need to cut the wire to make the ins and the links usually need to be drilled out.
Master club comes with plastic pins but not an issue, lend weight to the vehicle and comes with separate pads.
if I was to pick one it would be quickwheel due to construction time the Master Club
3D Micro Cosmos also do a number of different tracks for the M-113 as well as other upgrades. I feel that if you’re trying to spruce it up their stuff is a must! Check em out if you’d like. I’ve personally used a lot of these sets already and can say they are excellent! As a bonus to they always send a couple of free “gifts” with your order that normally have something to do with the main topic of your order. AND their cutomer service is excellent!
I think everyone is missing the point here - the question was specifically about the FabScale (FabArmor) M113 tracks. And given that FabArmor items - both their track sets and gun barrels - are about half the price of most other 3D producers, it’s a valid question.
I have their very first set of tracks, Ostketten, and I think they are well done, especially for the price ($17 USD from HobbyEasy). I also just recently received three of their new gun barrels (Merkava 4, Magach 6B, Canadian MEXAS) and they are excellent, especially when you consider that they retail for around $6 USD. That’s pretty much cheaper then me buying a file (if one is available) and printing it myself.
I was responding to DallBoy.
Thank you guys for the advice, I’ve bitten the bullet and purchased a set of the FabScale tracks from Hannants, which is a bit of a buggar as I received a consignment from them only yesterday, but hay-ho.
Standard delivery £4 and next day £6, I’ve paid the extra so should have them on Tuesday.
All being well, I’ll report in with may initial findings soon.
Good afternoon
My package from Hannants has arrived safely and on time.
Inside was a sturdy clear plastic box containing a bag of links, a length of copper wire and two jigs, used to measure the length of connecting rods.
The links themselves are crisply printed but I suppose time will tell when I start to assemble the tracks, probably this weekend. The fact that they are supplied singularly will be a big advantage as there will be no trimming and little if any cleanup. There is likely to be some drilling however.
Until next time, there’s a photo of the individual items
Hi Sean,
What scale is your copy, 12 inches to the foot?
Yes, we’re going to lose some detail and we take that for granted, but on the other hand they are one of the cheaper options out there.
The proof will be in the assembly, I’ve slung a couple together, I took the precaution to drill the holes slightly and the pin went in quite easily and stayed put. I can always apply a little sanding as I assemble the tracks, but that depends on how I feel at the time.
Thank you for the photograph that gives me something to work to, as I’ve never seen an M113 and it’s running gear!
