Face question....artist oils
hello , im back again , question about artist oils (gamblin brand) and faces , i used this method , I based with a vallejo fleshtone, after id dried and painted my eyes i covered the entire face ,neck forehead in burnt umber artist oil , then wiped 95% off with a small sponge , leaving all the shadow areas with the burnt umber , it looks really good but now i want to do highlights with the same artist oils and the last time i tried this , the highlight colors revived the very slim layer of raw umber on the face and it turned into a gray mess, should i let that face dry much longer?before adding the highlights?
How long had you been waiting? Oils tend to take a while to fully dry.
probably not long enough , but if i wait long enough . it should work nicely , any suggestions on how to tell if there dry enough to add the highlights?
Mmmmm, I seem to remember, someone working with oils hitting it with a thin coat of varnish between each oil coat. It was on a youtube video.
one way to tell if they are dry enough, without adding varnish, would be at the same time you put the coat on the face, but a patch on a piece of styrene sheet, then you could try applying over the coat on the sheet and if it’s ok, work on your figure.
i am always amazed at how long it takes oils to dry
Winsor Newton: Understanding-the-Drying-Times-for-Oil-Colour may be of interest.
Umber(s) tend to be one of the faster drying oil at around ~ 2 days per chart.
I’d also drain your paints on a piece of cardboard so that they can dry faster. I’d then transfer them to a palette for easier working for your needs. Draining them of their linseed oil cuts the dry time from multiple days to fully dry in a few hours (depending on the thickness of the coat). The thinner the coat, the quicker the dry time.
HTH!
Colin :grin:
Here’s my technique using artist oils over acrylic base colors:
Figure Painting with Oils
Face painting starts at about 01:03:00. However, the techniques for blending are covered earlier with uniforms and accessories.
ty you for that video
