Or some sort of platform instead. They can also climb directly from a flatcar into the gondola, but it’s a more involved process than just using a ramp.
The orange beasts are ballast regulators. The one in the foreground is a Knox Kershaw KBR 925 one.
and here’s a complete MOW (Maintenance Of Way) train
British Mark IV Female Tanks at Plateau Station, November 1917, aboard flat-bed railway carriages prior to transportation to forward area before the Battle of Cambrai.
From Africa
200-ton flatcar used by The Tanzania-Zambia Railway Authority to transport non-standard loads such as turbines for the construction of the Julius Nyerere hydroelectric power plant :
These large concrete boxes are prefabricated jail cells, assembled at a factory and transported to the site for fast assembly
New GE locomotive is headed to port
10th Mountain Division (Light Infantry) CONEX on the move
Henri,
wow! Where do you find some of these things??
Where are the prefab concrete jail cells?
I appreciate all these postings. Keep them coming. Thank you!
Fred
I don’t know but they’re/were available in HO scale from Atlas Model
A few more finds…
NASA Artemis 2 moon rocket booster segment
From Germany I guess
UK ?
Yes, near Berlin
"DB Drehgestell-Flachwagen mit der Nr. 31 RIV 80 D-DB 4865 336-0 Samms 709 beladen mit einem Bundeswehr Sattelanhänger 56 t, Tieflader, tmil, 12×0 am 10.01.19 in einem Militärtranportzug Bf. Flughafen Berlin-Schönefeld. "
Similar/Same type of waggons captured in Totton pulled by an engine
belonging to 'English, Welsh & Scottish Railway", “now known as DB Schenker Rail (UK), is a rail-freight transportation company in Great Britain. The company has historically focused on transporting bulk commodities including coal, metals, aggregates and petroleum. It also moves various forms of light freight and enjoys the right to operate through the Channel Tunnel.”
I get the impression that the waggons are Warwell (War Well) type?
That would be a colourful train on a model layout
Jingle Truck Express
Components for a lifting bridge bascule?
Mukkinese Battle-Horn?
M
I guess so : https://www.railpictures.net/viewphoto.php?id=597971
King size Ammonoidea ?
Sigh, … here comes Mr Boring:
Inlet duct for a turbine (Kaplan turbine??), I presume water turbine for hydroelectric power plant.
The Mukkinese Battle Horn idea is a LOT more fun though
