Hi All,
Sd.kfz 223 Afrika Korps 1:35 scale.
Recipe.
223/figure - the 223 is from Tamiya and built straight out of the box and the cam net is from JoeFix Studios and I cut is to size and added straps using paper. The 223 was painted and weathered using Vallejo Paints and pastel chalks and the figure is from Dragon and was painted using Vallejo Paints.
Base - is a piece of high density foam and the small rock ledge section was done by using a knife and cutting into the foam. The small rocks are kitty litter, the grass tufts are from Army Painter and the sand is a mix of spakfilla and sand.
Ron
That looks really good Ron. Nice use of the foam and how you have carved it. Looks very realistic. Painting on all of it looks great and you have given the veh a nice hard used look, with some very nice chipping and weathering. Great work
you’ve done a fantastic job on that old kit, well done indeed.
Excellent work. The figure is great and the vehicle is very well worn. Nice finishing and weathering.
Thanks so much Johnnych01
Thank you Klaus-Adler
Cheers Cheyenne
Thanks heaps SSGToms
Ron
Great work on the classic Tamiya kit. Where is the figure from?
Thanks heaps Stikpusher and the figure came with this kit from Dragon,
Dragon 9032 PZKPFW III AUSF. G AFR.
Ron
