German Z-26 Destroyer (Dragon 1/350)
Found a few minutes to do a quick and dirty rigging job. Its an amalgamation of about 7 different versions I saw on other peoples Zerstorer kits. I swear every single one had a different rigging layout :smiley:
It will do the trick when she is in my cabinet.
Just railings to go and those should go on quick!
Launch day is upon us. I was able to find some time to finish up the railings and put down my last layers of gloss/dull coats.
Before anyone says anything, I know there is a broken piece of rigging on the rear mast in the pics. Its already been fixed :slight_smile:
So without further ado, here is my Dragon 1/350 Z-26 Zerstörer
I went back and added a few more lines of rigging to the rear mast as it looked a bit bare.
She is not 100% accurate to the plans. I added the Quad 20mm Flak instead of the single 20mm just to add some visual interest. I am also pretty sure the dark grey stripes aren’t dark enough but I am ok with that.
Build wise, typical Dragon. Over engineered with too many fiddly bits. Instructions too busy and often times vague with placement. I also 100% believe that the single 20mm guns are massively overscale :rofl:
Overall though, she went together well and didn’t present any major headaches.
Thanks for following along and I will see you all for the next one! :smiley:
Great job on a Dragon kit, really like the Cammo too.
Cheers, :clinking_beer_mugs: Si
Superb stuff, Rory! Another great build :smiley:
Beautiful DD, Rory - the build and angular camouflage nicely capture the menacing, purposeful look of the German destroyer.
Great build, Rory, tidy, crisp and clean, a fine model doing the Z-26 pride!
I know what you are saying about Dragon instructions and over-engineering…
Congratulations to commissioning, job very well done!
Jan
