I am building a Hasegawa Ki-84 as a late war home defense/ B-29 interceptor and as such want to do some chipping. Nothing crazy, but some around the wing root, leading edges, etc.
I have done hair spray chipping before but never on anything this scale (usually just a small tool or exhaust stack). I had a question regarding timing, and how long I can wait and still activate the hair spray with water. I had two strategies planned out
hair spray the lower surfaces, paint the lower base coat, chip, then seal with with future to prevent further chipping. Repeat on top sides
hairspray everything, paint bottom and top side base coats, chip everything, seal.
Approach 2 is probably easier, but, I will likely only have time to paint one side per night. Meaning the whole process will likely take 2-3 nights. I worry that if I leave the bottom side paint to cure too long, chipping will be tough. Is one approach better than the other?
