Every time I build a truck or whatever which has leaf spring suspension, the manufacturer always has the mould line running along the leaves. For 40 years I have carefully removed the mould line and scraped the leaves clean. Now, I was leafing through the Haynes Manual on the Flak 88 and come across this picture. Have I been doing it wrong all these years; should I have been adding welds?
God, thatās weird! Never seen leaf springs like that before!
Ken.
There are several different types of leaf springs; some show a ridge and others donāt. It is an artifact of the manufacturing process. If it was a weld there would be a chance of the leaf splitting, so it isnāt that.
Opel Blitz
One issue to fix on āallā kits is the ends of the individual leaves. Mold technology results in the ends being rounded
Probably a casting seam.
Crap! Next weāre gonna find out tank gun barrels really have mold lines too!
Maybe a stiffening or reinforcing ridge on each leaf?
Well, at least Iām not the only one stumped! In the original photo in the book (sorry mine was taken with a phone) itās pretty clear that they are welds. The only thing Iāve seen similar is the weld when you join a band saw blade before grinding it smooth. If leaves show a ridge other than a weld, surely itās not a casting mark?
How Itās Made (tv show)
Leaf springs
Thereās no denying the OP photo showing ridges, but I couldnāt find anything about them.
The groove on the bottom fits on a ridge on the top of the next spring. It is designed to keep the springs aligned and stop twist. It was quite common on German heavier vehicles. The SdKfz 9 has the same feature:
So a seam on the top is correct inc some casesā¦but that means a groove is needed underā¦
The timing of your post couldnāt have been better. Iāve got a Famo arriving today! Saves me the hassle of smoothing those parts.
Wow, thatās something to think about! Fortunately not all were the same
T-26 for example was plain:
But yes, I bet I have done it wrong a number of times during my modelling lifeā¦ assumptions are not always safe.
I see another niche for the rivet counter personalities, groovy ā¦
I presume that the material used for the spring leaves was the same in all the leaves so the longest one needs a groove on the visible side ā¦
Definitely a case of bringing documentation to a contest.
Another case of no weld line.
Nice video, now I just need one on how to make 1/35 springs.
A variation on a Hotchkis spring
from Leaf spring | Tractor & Construction Plant Wiki | Fandom
The operative keyword is: ātediousā
I had to build a new front spring for a 1/35 GAZ-66 from Eastern Express (I lost the kit part somehow).
Luckily Evergreen had styrene strips that were close enough in width and thickness so I didnāt have to cut strips. Make the longest leaf way too long and glue the ends down over a form (elliptic) made from thicker styrene (CD-cases for instance). Mark the centre and start gluing the shorter leaves on top of the longest.
That Hotchkiss spring would need to be done from PE-strips with a half-etched groove.
Assembly would be the difficult part ā¦
erā¦Pass!
If you were to do that on something barely seen, I would know which side of the debate on ādedicatedā vs ābarking madā I would lean toward.
Woof, woof, wooof ā¦
