Before tackling the roof hatches, I modified the rear view mirrors supports. Heller gives a basic part with no details and which can only be installed in the unfolded position but with no mirrors. So I modified the whole thing as it should be in the folded down position.
Thanks for the comments.
I detailed the inner face of one of the troop compartment hatches. All the parts for the second one are already cut and ready to be glued. So it should go easier and faster.
Walter, the antislip is made with Mr Surfacer 500 brushed over the surface and then tapped on with an old brush. The French antislip is quite coarse so I find this method pretty efficient.
I made the second hatch. I also temporarily attached the commander hatch hinge system to give an idea of how it will look in the end.
Thank you all for your support.
I finally added the smoke dischargers using the tubes from KMT with the grenades from Blast Models as well as the hanging caps.
I’ve dryfitted the wheels from Djiti. They just need to cut the axles a bit to properly fit.
It’s really taking shape now Olivier. The hard work has paid off tenfold as it’s is now a kit and a half with all the extra detailing you have added. Be great to see the cam on it
