Junkers Ju-87R Stuka
Item No - 02423
Scale - 1/24th
A long range version of the Ju 87B was also built, known as the Ju 87R, the letter being an abbreviation for Reichweite, "(operational) range". They were primarily intended for anti-shipping missions. The Ju 87R had a B-series airframe with an additional oil tank and fuel lines to the outer wing stations to permit the use of two 300 litres (79 US gal) standardised capacity under-wing drop tanks, used by a wide variety of Luftwaffe aircraft through most of the war. This increased fuel capacity to 1,080 litres (290 US gal) (500 litres in main fuel tank of which 480 litres were usable + 600 litres from drop tanks). To prevent overload conditions, bomb carrying ability was often restricted to a single 250 kg (550 lb) bomb if the aircraft was fully loaded with fuel.
This is partial text from the full article (usually with photos) at https://aeroscale.net/news/junkers-ju-87r-stuka
