KM Model: Schutzenpanzerwagen U304(f) mit 2 cm Flak 38 (late version) | Armorama™
New version of the U304(f) half-track transporter, equipped with the late version of a 2 cm Flak 38 automatic cannon which was one of the Wehrmacht's most popular light anti-aircraft guns
This is partial text from the full article (usually with photos) at https://armorama.com/news/km-model-schutzenpanzerwagen-u304-f-mit-2-cm-flak-38-late-version
It’s not Surprising that the Germans mounted the Single 20mm on any Vehicle that could carry it.
Is it a captured french Suma half-track? Or a Citron one?
Unic.
Thanks..
Interested. It seems this KM offering may have the same issues the Somua MCG S307 7.5cm Pak version has.
The gun and cradle seem to lack some detail and the scale may be a tad too big.
With the S307 7.5cm Pak version, I had to replace the entire gun, customize the barrel and shield to match the size of the chassis/hull and completely redo the the interior.
Luckily with this one, you won’t have to redo the interior. There’s enough reference material out there and surviving examples that dev was able to make an accurate bed/gun platform.
Just a heads up, if you go with these KM models you’ll have to use the largest figures you can find (Jaguar, Hornet, Warrior, Verlinden) or bash/scratch your own because Dragon, Alpine and especially Tamiya will be way too small.
