Now that you know about it it will always be there in your mind when you look at the finished model:
" …the buffers are wrong…maybe I should have fixed them …"
Thanks Robin.
Hi everyone, I gave the primer and as advised by Robin I modified the two rounded buffers.
And I believe that I will not make the second railway wagon that I intended to make, the locomotive took me too much time, so I will adapt it to the diorama with some other details typical of railway stations.
Until next time.
Marino
Tremendous modeling skills!
J
FANTASTIC work with the locomotive and I look forward to seeing the painting
Scratch building excellence!
Beautiful work Marino , scratch building in perfection !!!
OUTSTANDING WORK !
But I have always wondered - why not just make BOTH buffers convex?
ALSO ~ Which “side of the locomotive” (driver being on the right) gets the convex buffer???
Thought of that myself- I think it must be for bearing surface area - much more contact area with convex/ concave pairs than with both convex so less wear .
Marino, you are an inspiration. Your modeling is amazing. Looking forward to your next post.
When you stand between the buffers, facing the other wagon/engine/whatever, the convex buffer is on your right side. The opposite wagon/engine/whatever has its convex buffer on your left side facing your flat faced buffer.
As RDT1953 writes: convex-to-convex would give a smaller contact area → excessive wear.
Since the railroad vehicles have suspensions they will flex up-down and wiggle sideways so two convex surfaces would cause problems when the contact points shift sideways.
Convex meeting concave would allow for angle changes, give the largest contact area BUT
it would fail spectacularly since it would not allow any misalignment due to suspension compression, misaligned track or the jiggling and wiggling when going through switches.
Convex to flat is the optimal solution, unless you use center couplers which combines buffer and coupler into one unit
Makes good sense!
That was very black indeed
Looking forward to the final result!
Looks really good looking forward to the rest
Robin, yes she is really black … it looks like Batman’s car … but now the worst (for me …) is getting older …
Micke …
Thank you guys.
Marino
