Wanted to share a few pictures of my refurbished & repaired 18 year old Tamiya M1A1 Abrams.
Background- The kit was purchased in the early 1990’s for like $13 at one of those mall toy stores like K·B Toys that have all but disappeared. I was delighted with the purchase as several friends had bought the same Tamiya
kit #35156 for like $35 at the local hobby shop.
The kit was finally build, painted and weathered in early 2003 after a four year break from the hobby. A friend provided the “Loreli’s Gem” decals from a DML M1A1HA kit.
Contest travels & tight rubber band tracks took their toll on the model. Basically the suspension imploded one day at a contest with commander side drive sprocket snapping. I guess the sudden release of tension on just one side caused both idlers to split and shear of the shared plastic axle. In anycase half of one idler was lost.
Eventually replacement parts and tracks were located but I lost focus on repairing the model. I was active about two years before taking another extended break.
So finally after waiting patiently in a copy paper box for eighteen years and enduring several moves, the old M1A1 spent the last two weeks on and off the hobby desk.
Half dozen or so loose broken parts were reattached or replaced. Road wheels that sheared off of their axle spindles were super glued back. Replaced missing barrel on MG 240. Rear sprocket was repaired. Idlers repaired and glued flush as the axle had disintegrated. New rubber band tracks painted and weathered. The new rubber bands are loose and tacked in place so as not to over tension the very very fragile idlers.
A new base was used as my base finishing improved over the years. The original name plate “Loreli’s Gem” was retained.
The antennas have lost their tension over the years but I’ve decided to leave them well enough alone.
Really great build, even better as a recovery/rebuild!
One small thing, in ODS the optics did not have the red anti-laser coating. May be too late to change that though. Still looks good!
Good rebuild. A couple things still missing/off though. The coax MG barrel cover to the right of the main barrel is missing. Also, the antennas should be dark green, not sand.
Thank you all, I appreciate the comments and suggestions.
The coaxial MG cover maybe one of the long gone parts. I’ll see what can be rounded up for a co-axial MG cover.
I will touch up the antennas with dark green as that’s an easy fix.
What would be the correct look for ODS M1A1 optics? Suggestions on how to model that?
I’m reluctant to try fixing the red tint optics error on this one but would like to know for future builds. Thae red tint will remain a legacy goof up.
Looking great. If you still want to address the optics, this is how I do it. First, I paint them flat black, then a couple coats of clear green, and a couple coats of clear flat.
You had to go and point that out, didn’t you
I have seen it for quite some time and each time I saw it I said to myself: Don’t mention it, don’t mention it, don’t mention it …
Oops. I misspelled it, but still contend it is probably named after a girlfriend or the TC’s last name. Based on what I know of soldiers, I doubt it is named after a German legend about a maiden and a big rock. We may never know though.
