I wonder if this will fit the M36 as well?
John. there is no reason why, if it’s designed for the M10/Achilles that it should not fit the M36. However, if one was to use this, naturally it would be an open hatch model. Therefore, the driver’s instrument panel will be necessary. Note that for the diesel engine M10 and Achilles it should be a specific type. The M36 with the Ford GAA engine had a different instrument panel. Furthermore, the radios on the M10 and M36 are visually quite different from those seen on US tanks. Finally, the Achilles or British M10s need a completely different radio, the No.19 type with the A and B aerials.
