Hi all,
I found a pic of a M16 with the side of the “box” folded down, but only the aft part and a soldier over the unfolded part.
I want to know if this a field modification, or its standart feature, or just an optic ilussion
TIA
Alvaro
Hi all,
TIA
Alvaro
@Alvaro_Brasesco Hi, they are normally bolted together at that point and operate as one but it would be easy enough to take apart in the field.
Thanks for your quick response, as you say I have always seen everything as a piece, I did not know that it could be used that way.
Thanks for the pic!
Thanks great detail!!
If the connecting plate was removed to allow independent folding, would that result in bolt holes all the way through or sockets?
I guess the four bolts would be removed as well so you would see four holes (two on each plate )
They are thru bolted
I guess they would put the bolts back in so they wouldn’t get lost.
If they were smart
