M1A2 Abrams kit wheels with outer lip?
Which maker makes one? My admittedly quick research shows none.
If you are refering to this style of wheels
I am pretty sure panzerart makes a set
Thanks, but I meant this style, with the lip around the inner rim:
T-rex
Thanks. I’ve used their British WWII antenna base, so I know they do good stuff, However, I did find a source in plastic that I’ll probably end up using. Waste of a good kit though.
@Petition2God made an Abrams wheel set. Maybe he can modify his design to incorporate the lip if it is not already designed as such?
