Anyone who’s built the Trumpeter M1078 or M1083 knows that the doghouse, or engine tunnel if you prefer, is not wide enough, That cause a few problems, the most critical at the moment is that it throws the proportions of the dash off. The more correct Foreart dash is shown above the Trumpeter one, which shows how different they are. And as the Kelik set for the Trumpeter kit is based on this same dash, even those 3D printed items are not correct, the center portion being too narrow. Even if you wanted to add the missing items, you’d be hard pressed to get them to look right. That top box would extend too far to the right.
I suppose I could have taken a ‘before’ photo, but the ring on the roof isn’t broad enough, so off it comes. Cut a new cover which will get a hole for the hatch in the center, as well the hatch itself.
There’s a reason I never toss out parts. The chrome ring is from an AMT Peterbuilt - that I built about fifty years ago. It’ll line the edge of the hatch opening, which still needs to be widened a bit.
The right sponson lockers house things I’ve been asked not to share - the Universal Launcher Interface, and Ruggedized Memory Unit to name a few. However, the left sponson is for crew gear, so I’ll be able to show some of that nice Legend gear:
Everything still going to plan. I modified the chassis to accept the older Trumpeter wheels, but more importantly to the correct width. The even still spin for easier painting, although I’ll just leave them off for now.
