I think most of you have seen the WIP of my scratch build Urdan Dozer Blade for the Puma in the old forum. It has been a long time in the making but managed to finished it around November 2021 with the help of my friend sharing his personal walkaround photos of the blade for me to complete the project.
Late posting of the finished blade fully casted in resin. The master is moulded in a vacuumed silicone RTV mould which is also pressure cured. The blade is then pressure casted for maximum detail and minimum bubbles. I will continue to cast this blade in summer when the temperature is ok to avoid cure problem due to low temperature.
The blade is fully workable as I designed it this way. I still have to turn an aluminium rod to represent a hydraulic ram to fit to the hydroelectric unit.
The blade is full scratchbuilt and NOT resin printed. I still have the old WIP in the old forum under my name (r2d2). Enjoy!
