Hello,
Do the Mk19 can be used without the feed throat ?
The item in 1:35 scale from MicroCosmos does not have this part molded on.
Hello,
Yes it can.
Thank you.
I have only found pics who show a training situation with a disassembled feed throat and ammo box not carried in holder.
I was not sure the feed throat could be removed in combat situation.
In combat that feed throat can save your life if you’re pounding them with a f ton of 40 Mike Mike.. the belts tend to backlash when feeding it a lot of rnds instead of a couple at a time.. it keeps the belt from fouling. So you can keep stacking bodies and making the grass grow
Doesn’t the Blue denote practice rounds? Cuz they sure do here.
It does. Blue - Training.
I have found pictures without feed throat and real shells. With a caption which talks about an operation in Afghanistan.
https://picryl.com/media/linked-40mm-grenade-launcher-rounds-feed-into-a-mk19-e7c52f
