Quick Track Question
I really like them , they goto together very well , some breakage , they are delicate , my real issue is connecting the last 2 links making the full track , to me its difficult .
Any suggestions?
My mind…
I read this as a quick question about tracks, not a question about “quick tracks”.
Oh well. When I do tracks of similar makeup I do the run as needed, less the last connection while leaving the idler and one or two of the front road wheels unsecured. Then I connect the run of track while off the model, then finesse them on along with the idler and however many road wheels I left off.
It tests my patience and manual dexterity but it works.
The one set of Quicktracks I used had a couple of links different than the others, and some pins to join those with. AFAIK, these are for the ends of the track.
I have also found it easy to use a drop of CA glue to close the run.
The M113 tracks I used also had the different links that closed the run using a rod, which set are you using?
Which tracks and which model?
Thanks for all the advice …T62 , no rod came with it
And thanks for all your replys
