After a few days away from the bench , I’ve been able to do a little work on the Churchill range target.
More to come.
Interesting concept
Wow that looks great so far!
@metalhead85 . Thanks brother. Ive looked at a ton of range target images and kind of taking a little something from all of them to do this one
And where will this beach be?? I’m curious how to deal with the wreck…
It is not a beach .
It just a random gunnery range target
What sort of range is meant to be ? Modern, early cold war ? Tank range ? Small arms range ? If it’s a tank range, you need a ton of penetration and exit holes…
Same for the screen affair to it’s rear.
If you are going to have the tracks on the finished Dio, they would be better off fitted or at least blown off with various impacts and split… And as rusty as the hulk …
There would probably be a bit of vehicle colour still on it as well …
It’s a nice plan… Looking forward to seeing develop.
@Johnnych01 . I was enviosining cold war era mostly small arms . Also thinking its been abandoned on that part of the range . Im still undecided on the tracks
Ok so if it’s a SA range, I’d have a ton more pock marks all over it.
As to the tracks, they still need to be rusty, but definitely not just dropped over the top like in the few shots above. Maybe just have positioned around the idler and split at the sprocket end or hanging very loose.
Also if it’s an SA range, you could still have small AT type weapons firing on it, so a few larger penetrations wouldn’t be amiss …
That is exactly what i needed to know . Ill make some adjustements.
Kinda working in uncharted territory for me
There are pictures of range wrecks on here by Ian Barraclough
Here are some photos from the net:
That should give you some good ideas. I really like the Chieftain at the end. The sheet metal bits have been completely shot up with small arms, but the armor is undamaged!
@tankerken . Those are nice to add to the reference i have .
They also give me a few ideas as to what needs a bit of re working.
Thanks for the help
