At the last Saumur Model Show, I was lucky enough to find a second hand Ratel 90 kit from Fire Force Products.
The kit seems quite fine but I’m looking for a walkaround to correct or add details.
The only detailed pics I found (on War Wheels.net) show a “modern” version with the front plate protecting the lights.
Is there a lot of difference with the earlier Border War version, apart from the wire cages protections for the lights ?
TIA for your help.
Salut Bruno
Did try here https://tanks-encyclopedia.com/coldwar/south_africa/ratel/
Some videos could be helpful.
Olivier
PS : est-ce pour le monter ET le peindre ?
Tu en demandes beaucoup, Olivier !
I saw the link but the pics are only of “modern” Ratels, not the early ones from the border War.
I have some books. I need to look inside to see if something could be useful.
Olivier
I guess this one is the early model
That’s it, HP !
Merci.
If you have pics close enough to see the details…
