Revell 1/570 Scharnhorst PE
Hello, newbie here. Does anyone know if there is a PE set for the above to enhance the kit. I know there are some bits in the wooden deck set but thats all I acn find. Even 1/500 would do?
White Ensign does a 1/600 that fits rather nicely. You will need the Ultimate Kriegsmarine Set No1 for the cranes, catapult etc and the Kriegsmarine set No2 for the railings.
Thanks very much - I found those yesterday from recommendation by Peter Hall at Atlantic Models. The UKS set isnt cheap but it is enough for 3x ships so that would be good. Cheers
Check out the AA gun set too, it is pretty cheap and will improve the look of the model a lot.
Is that also by White Ensign?
Yes you can find it here
Thanks - appreciate your help
