Build log Day 15
Got the camo on. Now I gotta do touch-ups.
Well it feels like progress, but I don’t think I’ll be done by Thursday like I hoped.
Build log Day 15
Build Log Day 16
Did touch ups all night.Got the riggingplaced back on the wing that I’d pulled out. Maybe I can do some assembly tomorrow.
Braille scale Tripes and Bipes and early monos … patience, perseverance and repetition. Worth every frustrating moment when it all comes together or so I hear. You’re motivating me to actually finish a Dr.1 that’s staring at me from under it’s dust cover. Keep up the good work.
Build Log Day 17.
Starting to look a little like a SPAD. Wing is in place, now I just have to start pulling the rigging.
Build Day 18, 19 and 20
Well day 18 was mostly a waste as when I tried to start pulling the rigging, the top wing popped off.
Day 19 I got the interplane struts replaced and the inner 6 (top wing to fuselage lines pulled.
Day 20 I got the starboard mid-wing lines placed and started on the port side, but one of the lines had to be replaced.
Build Day 21
Good news, Bad news.Had to give up bench time so that my grandson could work on his models. Managed to get most of the port wing mid wing rigging done.
Build Day 22
I’m calling this progress. I tried to start routing the rigging, found a couple of lines were missing, too short or pulled out as I tried to route them. They’re all replaced now and ready for final routing and supergluing into place.
Build Log Day 23
!@#%^ I had hoped to make real progress today. Hoped to get all of the wing rigging done. Got the inner rigging done.
Build Log day 24
Soo close, started to clip the outer lines for gluing and one pulled out… Well got 6 of the remaining 8 lines pulled and glued.
Build Log Day 25
Finally got all the wing rigging in place. Even got the fuel tank? painted.
Build Log day 26
Finished up the wing rigging and painted over the holes in the bottom wing. Also touched up the doped linen that I messed up.
Keep at it, she’s coming together well now.
Build Log Day 27
Had to re do the undercarriage. It seems solid now. Routed the rigging and anchored the lower wires. I’ll tension the upper lines tomorrow.
A lot of patience being exhibited here Mark
Build Log Day 28
Undercarriage rigging completed.
Build Log Day 29
While trying to re drill the holes for the rudder controls I managed to break loose the stabilizer rigging. AARRGGHH. Well got the rudder lines anchored, but I may have to wait till I get the rudder decal on to finish the line.
Build Log Day 30
Spend almost all night on touchups. Fixed what I could, and added a cockpit coming.
Build day 31
One step forward, Drilled out the cowling to accept a bass tube to hole the propeller. Should be slick enough to allow the prop to spin when you blow on it. Kind of a thing in my model club.
Build log day 32
Finally got the clear coat on!
Congrats Mark, you’re into the home stretch. Looking good.
