Hi all,
Im new to all things plastic, my dilemma is i have an revell a400m in 1/72 and contemplating a diaroma coffee table.
For me to add other aircraft, vehicle, buildings ect would i have to use the same scale.
As you can imagine the a400m is quite large as where a 1/72 build would be relatively small .
Any help would be much appreciated.
Hello,
Yes, the A400 at 1/72 is quite large -over 60cm- but I am afraid I do not understand your question… What do you need?
Welcome aboard.
If you want to display the plane on the tarmac then you should use items that are also 1/72. If you want to display the plane in flight, then your items should be smaller scale to show the aircraft in the air, so 1/350 or 1/700 gives you the visual that the plane is in the air.
Or this
Course it’s your project and you can do as you want.
Hi ,as for figures and buildings do i need the same scale of 1/72.
For an raf air base scene
Yes, you need everything at the same scale, otherwise it would look weird…
graph that helps explain scale
