Sd.Kfz. 251/22 Pakwagen from Das Werk | Armorama™
Das Werk gives us a sneak preview of their upcoming 1/16 scale Pakwagen.
This is partial text from the full article (usually with photos) at https://armorama.com/news/sd-kfz--251-22-pakwagen-from-das-werk
Looks nice. Wish Das Werk would come out with a 250 as well. I wonder what happened with the Puma that was previewed?
I’m sure the Puma is on the way as well, but the 251/22 is easier to produce since 75% is already done with the base SdKfz.251. And of course, once they have the Pak 40, I expect the SdKfz.234/4 will be next. After that, I could easily foresee the 251/9 and Sdkfz 234/3 as these will again be quite simple to do with the base kits already done, and being able to get two kits out of the L/24 gun.
Let’s not forget a possible 234/1! :slight_smile: That then leads to a potential 222…I guess it goes on and on. In the end, I’m sure it’ll be a market-based decision for whichever kit seems most likely to be successful.
And, the option of a towed Pak to put behind the 251 already released.
Looks like Gecko will beat Das Werk to the table with this one…
At the rate affordable 1/16 kits of good subjects are coming out now, I may not return to 1/35 for some time. This fits my declining vision and finger control. Let it rain.
Affirm, lets hope someone - maybe Jeff SHIU - puts out a crew for it, too. Really left field stuff here, someone releases an RSO in 1/16 to drop this onto…
Right there with you!
The larger parts are so much easier to work with. Getting old sucks, but at least my favorite hobby is keeping up.
Yep, it sure does.
