Hello friends,
after the Flour coating with the Rice flour, I can now show the images too. ![]()
Here the Intertank Dummy already hangs in my tried and tested Flour chamber,
and is waiting for the UHU glue spray mist,
which has covered it here after some turns from all sides. ![]()
And then followed the generous Flour coating with the rice flour by using a sieve,
whereby the flour was pressed smoothly between several times with the finger, which this time everything went much looser from the hand. ![]()
Finally, the loose flour was removed by tapping at the rotating rod,
so that everything could dry thoroughly first, and then the excess flour could be brushed off. ![]()
Now I can also present the pictures after brushing off the surplus flour, which have pleasantly surprised me, ![]()
because now the proportions of the SOFI-Patterns fit much better to the diameter of the Intertank, which results in a completely different and more realistic look of the texture, ![]()
especially since the floured surface looks much finer and smoother this time, which is certainly due to the finer Rice flour. ![]()
And if I now imagine this structure with primer and painting, then this should presumably give a quite acceptable overall picture. ![]()
And then I carefully subtracted the Maskol bonnets from the Ramps,
whereby I had to realize that the ramp, glued onto the tape strips (left) had no proper hold and has gradually peeled off during unmasking. ![]()
Consequently, the splices for the Ramps should be exposed before the Flour coating and covered separately either with a piece of masking tape or with Maskol and then the Ramps to glue only after Flour coating. ![]()
Here for comparison a small photomontage of the new SOFI Pattern structure in the original image of the ET-8 during the Roll-out, which shows that it looks not so bad, right? ![]()
Source: forum.nasaspaceflight.com (Jester)
And with these positive impressions, I can now continue with a clear conscience. ![]()
which initially looked orange-brown, as here at my mission
