Research is both modelers’ friend and doom: it helps to build correct models and it shows more things that may/should/must be corrected or added, depending on the respective degree of AMS.
Case in point: I found that the Studer US6 had a sun visor for its driver. No problem to scratchbuild that:
But the b/w photos in the TM don’t show the color of the thing: OD like the rest of the vehicle, black, or some dark color that had already been used in the civilian truck version upon which the US6 cab was based?
Any ideas out there?
