I recently purchased the 1/35 Eureka shells for the 39 Kw.K37 for my Tamiya 251/9. These things look so small!! It looks like a man could easily pick one up with one hand and load it. Is this right or did Eureka make them too small?
Jesse
Yes, they were small. The Stummel used only a 75mm low-velocity gun. 75mm is just under 3" diameter for the shells and being low-velocity, they had short casings.
The various shells used with the 7,5-cm KwK 37 weighted from 4,4 kg to 6,8 kg ( https://fr.wikipedia.org/wiki/7,5-cm_KwK_37 ) …
