I’m going to use Tamiya panel liner solution on a model. This stuff is a totally different formula than Tamiya paints. I am going to apply it over a Future barrier/gloss coat. If using a Q-Tip to remove excess, what solution should I use to moisten the Q-Tip?
Mineral spirits will work fine or even Tamiya’s own X20 not X20A.
The product is basically diluted enamel paint.
Odourless mineral spirits will work as will X-20 enamel thinner.
I use Winsor & Newton : Sansodor | Jackson’s Art Supplies.
Andy
