Allright gents. I am prepared to open a can of worms here.
I am still working on my Sturmtiger and now am contemplating about how to paint the exhaust mufflers. Since one heatshield is missing, it is visible in full glory.
The question is: did it rust as most modellers display it, or not?
It is quite a big tube, so might not get that hot. I read from the site of @DByrden that the exhausts on the Bovington museum are not the originals, and they seem to be painted black. So that is no lead.
The Saumur has very strange exhausts which do not help either. The Kubinka ones have been painted over. Anyone got some solid information opposed to personal preferences?
From looking at the exhausts of heavy equipment such as bulldozers, etc., and large trucks. and even your own car, they usually look dirty and dusty brownish-grayish with patches of old rust. Chromed exhausts don’t count!
Now that would be fancy: a Tiger with chromed exhausts…
DByrden would not be amused! ![]()
Did the mufflers rust? Sure. How much and how fast? That would be a situational dependent question with a situational dependent answer.
They almost certainly started off as subcomponents that were fabricated and then given some sort of protective primer coating (at the very least, the typical red primer, but it’s surely possible that the Germans used some sort of nominally heat-resistant primer - perhaps a black or gray). After installation (on new or depot refurbished vehicles), they would have likely been overpainted by whatever camouflage paint the factory was specified to use on that vehicle.
IIRC, the Sturm Tigers were all made during the period of factory specified full camouflage, so the three-color factory applied dark yellow, red brown and green, 1/3-1/3-1/3, probably over whatever colors were still present on the lower hulls returned and the newly made upper hull primer (probably red). There may have been some number of replaced wheels resulting in combinations of original used wheels and new replacements. The exhaust mufflers may have been replaced (one or both) or, if still serviceable, may have been the originals.
So now, imagine an exhaust muffler that started off painted, likely in primer and then camouflage. The effects of heat gradually burning off that paint starting first in the areas of maximum heat and then spreading upward. If the mufflers were new replacements, then how long was the Sturm Tiger in operation? If the mufflers were original to the Tiger I, returned to the factory for rebuild, and then probably just camouflage painted over the existing rust, perhaps the same effect but accelerated - again, though, depending on the total hours that the Sturm Tiger has been run since it left the factory.
I’m sure, if you really wanted to “crack the books” and do some in-depth research and analysis, you could make a pretty good guess at estimating the operational life span of almost any of the few Sturm Tigers that were made and employed. Only about 18 were made, and they only saw limited employment in a couple of campaigns through Dec '44, with some very small number still in service into '45. So, the service life of most of them probably didn’t see more than a few tanks full of gas before they were abandoned, so only a handful of hours with the engines running hard and hot enough to start burning the paint off the mufflers. Some very few saw more service than that, so maybe enough to completely burn off all the paint with enough time to expose the substrate metal to air and water for rusting. Remember that almost any long-distance movement of these vehicles would have been by train, so an initial production Sturm Tiger that maybe saw action in Warsaw and then in the Battle of the Bulge wouldn’t have moved all that distance on its own power (and it would have spent the intervening time basically parked in rear, garrison / assembly areas - the Germans by then were not expending very much gas on just driving around training areas).
Look at what you’re intending to depict and its time and location and make a guess about the total operational life span of that vehicle and go from there.
Given that there are documented examples of vehicles that were given replacement barrels in the ‘naked’ dark grey heat-resistant protective coating and redeployed without painting, it’s reasonable to assume that the same coating would have been used on exhaust systems, but this is just theorycrafting on my part.
Hm… Interesting replies…
The photo of “my” Sturmtiger, shows a slight discoloration to the top of the muffler, which might be an indication of the beginning of rust, while the lower part appears to be the same as the rest of the rear:
I think that looks excellent and very realistic Erwin. Nice use of the rust tones but not over done, and restrained enough to indicate the short service life of the vehicle.
Looks great and actually a lot of the time it’s not actually rust on the exhausts; it’s baked on dirt. The dirt sticks to the hot exhaust and then bakes any moisture out of the dirt leave a hard coating stuck to the exhaust.
Tiger I hulk burning at El Guettar valley after being demo’d in place by US Army combat engineers. A decent look at the exhausts in original color
One of said Engineers prepping to make it go boom…
@SSGToms @Beast @Stikpusher Matt, Dave and Carlos: Thanks for your replies guys. I used a mixture of Dark Rust paint, combined with several colors of rust pigments , topped with some black smoke pigment. I also discolored the top of remaining shield by mixing the green with a bit of brown, as can be seen (albeit that is totally yellow) on the Bovington Tiger.
Is that 142?
That is Tiger 142 and the location is NOT the El Guettar valley.
Nothing to do with it, nowhere near it.
It’s one of a whole sequence of photos at TIME-LIFE that are miscaptioned. I tried to have them fix it. I even got the original photographer’s daughter involved. No response from TIME-LIFE. They aren’t interested.
But if you post one of their photos on your website… suddenly they get very interested and their lawyers contact you.
David
Be wary of using the wreck of 142 as a colour reference. It was inside this explosion. Parts of it got covered in earth and dust. You have to look carefully to find clean patches.
As for the shields : I’ve seen hundreds of photos. They are painted just like the rest of the tank at first. But they get very hot, and as the kilometers add up, they gradually discolour and become lighter in a random way.
David
Interesting observationt here…
What can be the cause of the darkening of the Bovington Tigers’ exhaust then? Different paint?
News magazines care nothing about accuracy. Years ago, when I subscribed to Newsweek, they had an article about Cambodia with which they had a photo they claimed illustrated Khmer Rouge with government soldier prisoners behind an M113.
Never mind the “Khmer Rouge” were squared away in FANK tiger stripe BDUs while the “government soldier” prisoners (including a woman) were in pajamas…
I faxed them and they replied, insisting it was as they claimed.
And a newspaper for which I freelanced, had a headline during the Bosnian fighting, “BALTIC FIGHTING INTENSIFIES.” Geez… Realize how many in an editorial meeting signed off on that.
Same newspaper had a sports writer pen an article about problems in Zimbabwe which claimed the guerrillas fought against the British for independence.
I called the editor and said the guerrilla war was against the white minority Rhodesian government subsequent to the Unilateral Declaration of Independence from the UK and that the UK was instrumental in bringing sanctions on the Rhodesian government.
Editor: “You sound like you might be right.”
Me: “I don’t just ‘sound like I am right.’ I am right.”
These people, they think they know everything while they actually know nothing. They don’t care to learn the actualities of history. They are too full of themselves. The noble “Watchdogs of Democracy…” ![]()
These are of course modern paints and may be differently affected than paints half a century before those used during 131’s repaint. The sooty deposits from the various apertures in the shields is interesting, but IIRC 131 was burning more oil than would have been usual.
I agree on the sooth. The picture of the original (see above, post 7) does not show any at all! So I guess that is particular to the Bovvy Tiger.
