Today I had quite a paint job to do. To have a break from camo painting I took care about many smaller parts which also need attention. So I painted wheels, tyres, propellers, hubs, exhausts, landing gear … Always liked the fish tail exhausts on the Mk. V.
The red hub in the back is for the Vb, the green one for the Vc. It took me 2 hours for painting 7 colours with some cleaning in between. All paints come from Revell. The props still need their yellow tips.
More work tomorrow …
In general I have no problems with high or low temperatures. Forecast for the next days here in the Southwest is up to 40°C again and no rain. But it’s not as dangerous here as in France, Spain or Italy. Pretty warm also inside my rooms but that’s okay. I do airbrushing any day. Today I do some final touch ups at the camo of the Vc, so I hope I can show more in the next days.
Good progress on the Spitfires these days before I have another short break next week. The props are ready for action. The difference in size of the blades is clearly visible. The left spinner is painted with Emerald Green (Revell 364), the right one with Carmine Red (Revell 36) …
Finished the camo on the Vc yesterday. It’s Dark Earth (Revell 82), Dark Green (Vallejo 71324); Sky (Revell 59), Black (Revell 302) and White (Revell 301). Here you can see, that Revell’s Dark Earth is bit more reddish, compared to Vallejo’s Dark Earth, which is a bit more greenish. Quite happy how everything came out here. Some minor touch ups here and there but nothing serious.
Finally I have some crocodile clamps free again now. With 3 kits on the bench I had 38 of my 40 clamps at work. Let’s see how far I get tomorrow, before I’m a week off(line) again.
Back at the bench since Monday last week, I came a lot closer to the finish line with my Spits. Both got Emsal Bodenglänzer all over now. While the Vc is flying waiting loops over the bench …
Spitfire Mk. Vb trop (AB502, IR-G) No. 244 Wing Tunesia, April 1943 Pilot: W/Cdr Ian Richard Gleed
Kit: Eduard 1/48
Paints used:
Vallejo 71031 Middle Stone
Vallejo 71108 UK Azure Blue
Vallejo 71305 Interior Grey Green
Vallejo 71323 Dark Earth
Revell Aqua 09 Anthracite
Revell Aqua 15 Yellow
Revell Aqua 36 Carmine Red
Revell Aqua 90 Silver
Revell Aqua 91 Steel (Gun Metall)
Revell Aqua 99 Aluminium
Revell Aqua 301 White
Revell Aqua 302 Black
and a mix of Revell Red Brown, Black and Steel for the exhausts
The build was a lot of fun and gave me no hassle, just like the Mk. II double build from a few years ago. The decals went on very easy coming from warm water. As usual I didn’t remove the transfer film of the decals. One can do it but there’s no reason to do so in my opinion. It’s easy to destroy the decals then. Final coating was again made with a 70/30 mix of Revell Clear Gloss and Clear Matt.
Thanks, Russell! Glad you like my effords. Yes, I also think it’s a fitting tribute to both pilots. One is buried in Lybia (Tobruk), the other in Tunesia. Maybe I present them together on one of the the coming shows.
So, the “Flying Wombat” has also crossed the finish line yesterday evening …
Spitfire Mk. Vc trop (JG912, UP-S) No. 79 Sqn, RAAF Kiriwina, Trobriand Islands (New Guinea) Oktober 1943
Paints used:
Vallejo 71324 Dark Green
Revell Aqua 59 Sky
Revell Aqua 82 Dark Earth
Revell 301 White
Revell 302 Black
Revell 364 Emerald Green
and the same mix of Revell Red Brown, Black and Steel for the exhausts
What I wrote about the Vb is also valid on this build. No real problems with it. Final coating was also made with a 70/30 mix of Revell Clear Gloss and Clear Matt. It’s my standard ratio for all builds.
Thanks Russell! As you know, not my first RAAF bird and surely not my last!
So, now that the Spits have found their parking position on my shelf of pride I had a look in my stash and grabbed a model which I wanted to build for some time now. Bought it on the model show of my Leipzig friends in 2019. It’s another Eduard kit, the Avia S-99, which is nothing else but the postwar Bf 109 G-10 in different colours …
The difference is in the painting and decals. I have decided to go with OK-BYH from the Police Air Patrol Unit in Brno-Slatina 1947. You can see the aircraft also on the box art …
At first finding the correct colours for this bird was a bit of a tricky search but meanwhile I found both Greys and the Red in my paint box. It will be again a mix of Revell and Vallejo. Will start with this build in the next days and hope to have some of you guys again at my side.
While I was reading the plan of the S-99 I thought, why not making it again a double build with something similar. Yes, why not? Not another G-10 in a WW2 scheme but this brandnew (from 2025) Avia S-199 came to my mind. It’s from Eduard’s new Hybrid line and has has many Brassin (resin) parts instead of PE-parts. Never had so many in one kit before. The first time using brassin was on the Mk. Vb for the wing tips …
I won’t open all bags now but I had already a closer look. Also here some smaller parts are broken off the sprues but they don’t look broken. Don’t know what the guys and gals in Obernice did to this box … I’ll show the parts later when I need them for the build. But as you already see here, the cockpit is one piece. So lots of brush painting …
Eduard offers 6 options for this build, 3 czech and 3 israeli aircraft. I have decided to go with this IDF S-199 from famous 101. Tayeset (Sqn.) from October 1948 in the times of the War for Independece …
Again it was a bit tricky to find the closest colour as Eduard suggest a 80-20 mix of differnt Gunze paints. As you know me by now, I don’t do any mixing but look for the closest and surprisingly I found it in modern Bundeswehr paints. Helloliv RAL 6040 comes close enough for me and I have it in my Vallejo paint box. It was used on Bundeswehr ISAF vehicles in Afghanistan …
So another dual combo but quite different to what I did before. For the brassin parts CA Glue is needed and I bought a fresh tube. Wish me luck for this build!
Furthermore I have started a Chieftain for the Royal Tank Regiment Campaign. So lots of traffic on my work bench in the next time …
Happy modelling!
Torsten
First small update on my Avias. Not much done though, just to show you that they’re on the bench by now.
The Avia S-199 has many 3 D resin parts and when I took the cockpit out of the bag I noticed that the right rudder pedal was broken off in 2 parts but still in the bag So this is the best repair I could do …
And this is the completely assembled cockpit. Some of the resin parts are very tiny and fragile. I still don’t have much experience with them so one of the trim wheels broke and the other one became an oblation to the carpet monster … Blame it on my clumsy fingers. But I planned to keep the canopy closed on this one anyway.
Beside working a lot on my Chieftain for the RTR Campaign I was able to tinker also a bit on my Avias.
I’m not that happy with these brassin parts. They have have great details, yes, but at least for the IP there should be some PE parts. Here you can see the difference. On the left the brassin IP for the S-199 with a decal which didn’t fit well. Okay, also my fault …
On the right side the IP for the S-99 with PE parts, which fit very well. Guess which one I like more …
Fitting of the rear part of the cockpit is not so good, but this is the only way it fits. Maybe I made a mistake. Hopefully most of it isn’t seen later when the canopy is closed.
The fitting of both fuselages is very good, so I could keep sanding to a minimum. Though I had to fill a little hole in front of the cockpit of the S-99 caused by the sprue gate. So let’s see how far I get in the next days. Another update soon!
Time for another update. I came pretty far since my last post. First I built the wings. Here you can see another difference of both Avias. While the wheel wells of the S-199 are resin and one part, the ones of the S-99 are made of PS and 4 parts on each side …
Just a quick update today. Masked and added the canopies to the Avias. Both are now ready for primer which I want to start tomorrow …
The S-99 gets an open canopy …
I took Revell 301 White for the narrow fuselage band. Adding the 6 mm tape from 3M was a bit of a challenge but as always patience does the job well … I also covered the side rudder for the red-white decal later.
Now both birds are ready for the paint. It was quite a session today. First the S-199 with an easy but time (and paint) consumpting job. Vallejo 71247 Light Olive over all …
Paint on the S-99 looks pretty wild now but in the end it will all be fine, I hope. It’s Revell 331 Purple Red, which comes closest to the desired tone …
Spinner and turbo charger intake are also in this tone but not on the photo. I have “Yellow Noses” and “Black Noses” in my collection but this is the first “Red Nose”. So I could call it Rudolph, the red nose Avia …
Will leave both builds now to dry thoroughly and check tomorrow if they need some touch ups. Main painting on the S-199 is already done, the spinner will be Red in the next days. The S-99 will get a few masking jobs soon …
Thanks Jack! Glad to know you around here and that you enjoy my work
A bit of work is done since my last post here. Both props are ready for action. S-99 is the usual Black Green from Revell 40, while the S-199 has Vallejos Light Olive and the hub is painted with Revell 36 Carmine Red …
After yesterdays club meeting I came home with enough motivation to work on the Mezek and she’s more or less ready for a good shower of Bodenglänzer for the decals. Some minor touch ups here and there but she’s on a good way. The fitting of the brassin landing gear is amazing though the fitting of the tail wheel into the opening gave me some head scratching. But I always win … The propeller needs a drop of White Glue in the end.
