So you think it’s laughable that the absence of something proves it meets a certain condition, huh?
I guess that makes you the intel expert in this conversation?
Ok, let’s try another example. (And remember this is only an example meant to explain the point)
Let’s say we wanted to compare a current Toyota Camry to a 70’s era Fiat. Both are cars, and both contain the same technology. But one is obviously far better than the other. Traditionally, Toyotas have had the reputation of producing some of the most reliable cars on the market, whereas the 70s era Fiat (or Fix It Again Tony) were known to have built some of the worse cars ever (and some may argue that they still do)
What makes them “different” (in terms of quality) if they basically use the same technology? Technology is a wonderful thing and maybe there aren’t any secrets, but technology alone doesn’t explain everything. Perhaps Toyota has a different ethic to that of Fiat, or holds to a different business plan. Whatever it is, they chose to build cars with a level of quality that beats many other cars on the market.
Now if you happened to live in Lada land, and that’s all you know, but then you hear about another brand of car which claims to be much better. You may want to acquire one to see if it’s indeed a better car. So, once you get it, you will drive it, study it, put it thru it’s paces and if it is truly a better car, you might want to find out why it’s better and then maybe, you take what you’ve learned and incorporate that into your Lada.
The Russians may already know everything there is to know about, say, -metallurgy. But not every nation which builds tanks are going to use the exact same mix of alloys and whatever they do use is typically held as secret. (Since differences in the percentages of materials in the steel alters the performance of armor) Therefore, you should conclude that the Russians would want to know the exacts, so that they could counter it.
Thats my point and btw, my crystal ball has been in the shop for the last few weeks.
Edro
