I was planning to make the Melton-coated Dragon Bastogne figures into field military police. I assume other than the armbands and MP helmets, they could be equipped like any other soldiers?
Also, box art can be inaccurate, so are the harnesses, belts, straps, etc. the right color, or are they something else?
They’ll wear the exact same uniforms as regular units, with the exception of the MP armband (brassard) and their helmets will have MP painted in white letters with a white band around the circumference of the helmet.
One thing to note, the band around the helmet may differ in color depending on the unit formation (Divisional units would have yellow bands, while Headquarters elements would have a red band). Also, some MP units would paint their divisional patch above the MP to further identify them
Case in point
But in general terms, a white band will suffice.
I figured as such but wanted to be sure. You see them traditionally with handguns but I assume in the field that have the same weapons as any infantry.
I just changed my mind and decided to buy Asian ripoffs (not Chinese) for better quality instead of Dragon.
Keep in mind when considering uniforms, weapons and equipment, that most MPs in the field are located in what might be called the “combat zone.” Divisional and brigade MPs are going to be employed all the way forward to the ends of the main lines of communication (convoy routes) and POW collection points (likely traveling forward to collect POWs from combat battalions and bringing them back to brigade / regiment collection points probably guarded by more MPs). They need to be armed and equipped pretty much the same as all of the other light infantry units employed in the same areas. Far to the rear, in the “zones of occupation” you would find MPs operating in their military law enforcement function, but their combat duties in forward areas are controlling “battlefield circulation” (traffic control and direction) and “POW guarding” and “critical facility (mostly higher HQ’s) security.” All of these functions demand a degree of combat capability about equal to that of any similar sized infantry unit.
