US Military Ground Vehicle Matrix (Chronological by Deployment Timeline 2001 to present)
I have been working on a list of US military vehicles (mostly focused on ground based) along with their deployment timeline and designated variants. Thought I would share.
Master Ground Vehicle Matrix (Chronological by Deployment Timeline)
Deployment Timeline Primary Vehicle Family / System Service Branch Military Designation Variant Models & Tactical Designations
1972–2021 (Phased out) Amphibious Assault Vehicle USMC AAV-7A1 (Tracked) • AAVP-7A1: Personnel carrier baseline hull
• AAVC-7A1 / AAVR-7A1: Command and Recovery configurations
1980–Present (USMC divested 2020) Abrams Main Battle Tank U.S. Army & USMC M1 / M1A1 / M1A2 • M1A1 HA / Common: Heavy Armor (1990s) / Marine deep-water fording setups
• M1A2 SEP v1/v2/v3: Digital System Enhancement Packages (2000s–2020s)
1981–Present Bradley Fighting Vehicle U.S. Army M2 (Infantry) / M3 (Cavalry) • M2A3 / M3A3: Digitized battlefield target acquisition (2000)
• M2A4: Upgraded powertrain, suspension, and high-draw digital computing (2020s)
• M7 BFIST: Fire Support Team precision targeting vehicle
1982–Present Heavy Tactical Cargo Trucks U.S. Army HEMTT Family (8x8) • M977: Standard 10-ton cargo platform with integrated load crane
• M1075 LHS: Palletized Load Handling System configuration
1983–Present Light Armored Vehicle (LAV) USMC LAV-25 Series (8x8) • LAV-25: Baseline reconnaissance variant armed with a 25mm chain gun
• LAV-AT / LAV-M: Anti-Tank (TOW missile launcher) and Mortar variants
1985–Present Humvee Utility Vehicle U.S. Army & USMC M998 / M1114 Series • M998: Standard unarmored cargo/troop utility bed
• M1114 / M1151 / M1165: Up-Armored Humvee (UAH) combat variants
1986–Present Armored Combat Earthmover (ACE) U.S. Army M9 Series (Tracked) • M9 ACE: Highly mobile tracked combat bulldozer used to excavate fighting positions, clear roadblocks, and fill anti-tank ditches under fire
1989–Present Avenger Air Defense System U.S. Army & USMC AN/TWQ-1 • AN/TWQ-1: Gyro-stabilized turret mounted to a heavy Humvee chassis carrying 8 Stinger missiles, FLIR tracking optics, and a .50 cal machine gun
1992–Present Paladin Howitzer U.S. Army M109A6 / M109A7 • M109A6 Paladin: Tracked 155mm self-propelled gun baseline variant
• M109A7 PIM: Upgraded chassis integrating Bradley components and a 600V power arc
1996–Present Light/Medium Tactical Fleets U.S. Army LMTV (4x4) / MTV (6x6) • M1078 LMTV: 2.5-ton standard short-wheelbase cargo variant
• M1083 MTV: 5-ton medium workhorse cargo and supply chassis
1997–Present HERCULES Heavy Recovery Vehicle U.S. Army & USMC M88A2 (Tracked) • M88A2: Heavy tank recovery vehicle with a 35-ton main boom crane and a 140,000 lb constant-pull winch to tow 70-ton main battle tanks
1998–Present Medium Logistics Fleet USMC MTVR (Oshkosh 6x6) • MK23 / MK25: 7-ton off-road standard Marine cargo truck bed
• MK31 / MK36: Heavy Tractor trailer pull and mechanical Wrecker configs
2002–Present Stryker Combat Vehicle Family U.S. Army M1126 Series (8x8) • M1126 ICV: Infantry Carrier baseline vehicle
• Stryker DVH: Double V-Hull blast-resistant design modification (Post-2011)
• M1296 Dragoon: Up-gunned variant with a 30mm unmanned turret (2018)
2004–2021 (Post-war divestment) Cougar MRAP Series U.S. Army & USMC Cat I (4x4) / Cat II (6x6) • Cougar H 4x4: Standard patrol and scout infantry unit vehicle
• Buffalo MPCV (6x6): Dedicated route-clearance rig with a 30ft robotic arm
2005–2015 BAE RG-31 / RG-33 U.S. Army & USMC RG-31 / RG-33 Series • RG-31 Type 5: 4x4 light variant utilized heavily by USMC and EOD squads
• RG-33L 6x6: Extended ambulance and heavy convoy command post variant
2005–Present HIMARS Rocket System U.S. Army & USMC M142 (6x6) • M142 HIMARS: Wheeled medium tactical truck chassis carrying a launch pod for 6 GMLRS rockets or 1 ATACMS/PrSM ballistic missile
2007–Present International MaxxPro U.S. Army M1224 / M1234 Series • MaxxPro Base (M1224): Core V-hull infantry transport variant
• MaxxPro Dash (M1235): Lighter variant optimized for tight turning radiuses
2008–Present Heavy Logistics Replacement USMC LVSR Family (10x10) • MKR15 Cargo / MKR16 Tractor: 5-axle heavy logistics transport truck
• MKR18 Wrecker: Heavy tactical crane vehicle for disabled MRAPs
2008–Present Assault Breacher Vehicle (ABV) USMC & U.S. Army M1 Series (Tracked) • M1 ABV (Shredder): Abrams tank chassis fitted with a full-width mine plow, combat engineer blade, and dual Linear Demolition Charge launchers
2009–Present Oshkosh M-ATV U.S. Army & USMC M1240 Series • M1240 Standard: All-terrain independent suspension baseline variant
• M1240 C-UAS: Contemporary build adding overhead electronic anti-drone towers
2013–Present Ground Mobility Vehicle (GMV) Joint SOCOM / USMC GMV 1.1 / Flyer 72 • Flyer 72: Lightweight, highly customizable open-frame tactical truck deployed by Special Forces and Marine Raiders for deep-penetration scouting
2015–Present Joint Light Tactical Vehicle U.S. Army & USMC JLTV (M1278–M1281) • M1278 Heavy Guns Carrier: Equipped with standard protected roof weapon ring
• M1279 / M1280: Utility Cargo and General Purpose transport beds
2016–Present Joint Assault Bridge (JAB) U.S. Army & USMC M1074 Series • M1074 JAB: Abrams tank chassis utilizing a hydraulic launch system to deploy an uncrewed MLC95 scissor bridge across gap hazards in under 5 minutes
2019–Present Amphibious Combat Vehicle USMC ACV Family (8x8) • ACV-P / ACV-C: Open-ocean personnel carrier and Command variants
• ACV-30: Heavily armed variant featuring a 30mm cannon turret
2020–Present Armored Multi-Purpose Vehicle U.S. Army M1283 Series • M1283 GP: General Purpose infantry carrier replacing legacy M113s
• M1284 / M1285: Medical Evacuation and Medical Treatment variants
2020–Present Infantry Squad Vehicle (ISV) U.S. Army GM Defense ISV • ISV: Ultra-lightweight open-frame truck on a Chevy Colorado base; moves a 9-soldier squad and fits entirely inside a CH-47 Chinook helicopter
2020–Present (Combat Testing) Robotic Combat Vehicle (RCV) U.S. Army RCV-L / RCV-M • RCV-Light: Hybrid-electric uncrewed tracked platform serving as a remote-controlled wingman; hosts anti-tank missiles, smoke arrays, and scout drone links
2021–Present Maneuver SHORAD (M-SHORAD) U.S. Army M1287 Series • M1287 IM-SHORAD: Stryker Double V-Hull (DVH) chassis hosting a Moog turret armed with Stinger missiles, Longbow Hellfire missiles, and a 30mm auto-cannon
2021–Present Uncrewed Expeditionary Fires USMC ROGUE Fires / NMESIS • NMESIS: Navy/Marine Expeditionary Ship Interdiction System; autonomous vehicle chassis built on a modified JLTV base to launch Naval Strike Missiles
2023–Present Mobile Protected Firepower U.S. Army M10 Booker • M10 Booker: Light/mobile tracked armored vehicle carrying a 105mm main gun to support Infantry Brigade Combat Teams (IBCTs)
Master Ground Vehicle Matrix (Reorganized by Major Conflict Era)
Operational / Conflict Era Primary Vehicle Family / System Service Branch Military Designation Variant Models & Tactical Designations
:shield: Cold War / Pre-911 Era
(Designed for high-intensity European plains)
Amphibious Assault Vehicle USMC AAV-7A1 (Tracked) • AAVP-7A1: Personnel carrier baseline hull (Phased out for active water ops in 2021)
• AAVC-7A1 / AAVR-7A1: Command and Recovery setups
• LAV-AT / LAV-M: Anti-Tank (TOW) and Mortar variants
Armored Combat Earthmover (ACE) U.S. Army M9 Series (Tracked) • M9 ACE: Tracked combat bulldozer used to dig fighting positions under small-arms fire
Avenger Air Defense System U.S. Army & USMC AN/TWQ-1 • AN/TWQ-1: Gyro-stabilized turret on a heavy Humvee chassis carrying 8 Stinger missiles
:collision: Operation Desert Storm (1991)
(The peak of heavy mechanized armor lines)
Abrams Main Battle Tank U.S. Army & USMC M1 / M1A1 / M1A2 • M1A1 HA / Common: Heavy Armor (1990s) / Marine deep-water fording setups (USMC divested in 2020)
• M1A2 SEP v1/v2/v3: Modern digital upgrade blocks
• M2A4: Upgraded powertrain, suspension, and high-draw computing (2020s)
Humvee Utility Vehicle U.S. Army & USMC M998 / M1114 Series • M998: Standard unarmored cargo/troop utility bed used during early Desert Storm lines
• M1114 / M1151: Up-Armored Humvee (UAH) combat variants added later
• M109A7 PIM: Upgraded chassis integrating Bradley components (2015+)
:globe_showing_europe_africa: Post-Cold War / Early War on Terror
(Transition to medium rapid-deployment units)
HERCULES Heavy Recovery Vehicle U.S. Army & USMC M88A2 (Tracked) • M88A2: Heavy tank recovery vehicle with a 35-ton main boom crane to tow 70-ton main battle tanks
Stryker Combat Vehicle Family U.S. Army M1126 Series (8x8) • M1126 ICV: Infantry Carrier baseline vehicle launched in 2002 to bridge the gap between light and heavy armor units
:bomb: Iraq & Afghanistan Counter-IED Surges
(Rushed production to counter roadside bombs)
HIMARS Rocket System U.S. Army & USMC M142 (6x6) • M142 HIMARS: Wheeled tactical chassis carrying a guided rocket pod; heavily utilized for standoff fires in Iraq, Afghanistan, and modern global sites
International MaxxPro U.S. Army M1224 / M1234 Series • M1224 Base MRAP: Core V-hull infantry transport fielded to replace unarmored utility vehicle patrols
• M1235 Dash: Lighter variant optimized for tight turning radiuses
Assault Breacher Vehicle (ABV) USMC & U.S. Army M1 Series (Tracked) • M1 ABV (Shredder): Tank chassis fitted with mine plows and dual MICLIC rocket-propelled lines to breach complex obstacle belts
Oshkosh M-ATV U.S. Army & USMC M1240 Series • M1240 Standard: Developed in 2009 specifically to merge MRAP blast survivability with off-road suspension for rugged Afghan terrain
:shield: Modern Near-Peer Focus (2015–Present)
(Optimized for anti-drone and distributed operations)
Ground Mobility Vehicle (GMV) Joint SOCOM / USMC GMV 1.1 / Flyer 72 • Flyer 72: Lightweight open-frame tactical truck deployed by Special Forces and Marine Raiders for air-droppable scouting missions
Joint Light Tactical Vehicle U.S. Army & USMC JLTV (M1278–M1281) • M1278 Heavy Guns Carrier: Core baseline vehicle built to replace frontline Humvee roles with an optimal balance of protection and payload
Joint Assault Bridge (JAB) U.S. Army & USMC M1074 Series • M1074 JAB: Abrams tank chassis utilizing a hydraulic launch system to deploy an uncrewed MLC95 bridge capsule over gaps
Amphibious Combat Vehicle USMC ACV Family (8x8) • ACV-P / ACV-C: Next-gen ship-to-shore open-ocean combat platforms
• ACV-30: Armed variant featuring a 30mm cannon turret
Armored Multi-Purpose Vehicle U.S. Army M1283 Series • M1283 GP: Tracked general purpose infantry carrier fielded to replace vietnam-era M113 boxes within Armored Brigade Combat Teams
Infantry Squad Vehicle (ISV) U.S. Army GM Defense ISV • ISV: Ultra-lightweight open truck on a Chevy Colorado base; moves a 9-soldier airborne squad and fits entirely inside a CH-47 helicopter
Robotic Combat Vehicle (RCV) U.S. Army RCV-L / RCV-M • RCV-Light: Hybrid-electric uncrewed tracked platform serving as a remote-controlled wingman for manned combat lines
Maneuver SHORAD (M-SHORAD) U.S. Army M1287 Series • M1287 IM-SHORAD: Stryker Double V-Hull (DVH) chassis armed with Stinger and Hellfire missiles to defend combat lines from modern drone threats
Uncrewed Expeditionary Fires USMC ROGUE Fires / NMESIS • NMESIS: Built for modern Pacific littoral island-hopping strategies; an autonomous vehicle base that launches anti-ship Naval Strike Missiles
Mobile Protected Firepower U.S. Army M10 Booker • M10 Booker: Light/mobile tracked armored vehicle carrying a 105mm main gun to support lightweight Infantry Brigade Combat Teams
The FMTV’s hadn’t fully replaced the venerable deuce-and-a-halfs and five ton trucks by 2003. There were still a ton of them in service in Iraq early in the war. In fact, my first convoys as an Active Duty soldier in 2003 were riding in the back of 5-ton trucks. In order to meet the requirement for a crew served weapon on a convoy, a soldier would stand in the bed of a 5-ton with an M-240B and rest the bipod legs on the cab of the truck. I did this several times. When I returned in 2004 they were still in general use with my first convoy with 1st CAV being packed into the back of a 5-ton riding down Route Irish to Camp Taji. In response to IED’s, soldiers would cover them in old flak vests (some National Guard units still had stores of M-69 vests that they used for this purpose). There was plenty of experimentation with “Hillbilly Armor” consisting of various types of steel plates (diamond plate was supposedly the best).
As time went on, they were removed from unit property books and left in Iraq. Lacking Army issue up-armor kits, units would get issued them sometimes as “FOB runners” for administrative use inside the wire. Presumably these trucks were transferred over to the Iraqis.
Fun fact, in 2003 one of our northernmost mech companies was ambushed during a convoy down to the battalion main base outside Muqdadiyah. The 5-ton truck door on the driver’s side stopped several AK-47 slugs and the driver was unharmed.
